what would you do?
Old Dec 8, 2005 | 12:41 AM
groundpounder's Avatar
groundpounder
Sith Lord/Site Mod
Default what would you do?
My gas mileage just went from 15.75 to less than 13, and the cockpit reeks of gasoline. What would you do?
I understand there may be more than one answer - what would you most LIKELY do??
Old Dec 8, 2005 | 12:44 AM
downwardspiral's Avatar
downwardspiral
Default RE: what would you do?
ORIGINAL: groundpounder
Isnt it obvious? I mean seriously, you would have to be a retard even to post that. We all know the right thing to do is to take care of the problem..... by getting high. It solves everything, and thats how you become famous. It might also be a good idea to find the leak, but thats only if you feel like it.
Old Dec 8, 2005 | 01:54 AM
mkspeed26's Avatar
mkspeed26
check near the fuel filter and the tank fittings
Old Dec 8, 2005 | 03:34 PM
groundpounder
Sith Lord/Site Mod
Any other ideas?
I know it must be a gas leak. The heck of it is that there isn't any evidence of leaking underneath the car. [sm=dontgetit.gif] [sm=feedback.gif][sm=helpout.gif]
Old Dec 8, 2005 | 04:23 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
Any other ideas?
If the leak is not obvious, it's going to be the fuel pump or fuel rails or something that is pressurized in the fuel delivery system.
Fire it up and look for leaks, then if it's still not obvious, rev it to create some pressure.
Of course, you will need to be high to properly perform this procedure.
Old Dec 8, 2005 | 04:48 PM
downwardspiral
I would just like to add, do you know where the term rule of thumb came from? There was a law that men could only beat their wives with an object the diameter of their thumb. Needless to say, the rule was revised to meet modern standards. As it stands now, men can only beat their wives with a mullet.
Old Dec 8, 2005 | 05:35 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
how the hell do you beat your wife with a mullet?
Old Dec 8, 2005 | 06:04 PM
5.7litereater's Avatar
5.7litereater
He means that you have to HAVE a mullet in order to beat your wife. Or in my book, you just need a good reason
Old Dec 9, 2005 | 03:07 AM
groundpounder
Sith Lord/Site Mod
Hijackers!! Haters!! HA HA!
I was about to bow up on spiral, then I read the his whole post and I felt stupid. Funny!
Old Dec 9, 2005 | 11:10 AM
StupidTodd's Avatar
StupidTodd
I had a similar problem on my truck...
I knew gas was leaking, but I couldn't tell where it was coming from...
The reason I had trouble finding the leak, is because it was leaking directly onto the hot exhaust and immediately evaporating.
A word to the wise, don't try to weld a gas tank closed. Use J&B weld. It's just as good, and the chances your gastank will explode are far less. (even though I'd drained and flushed the gas tank multiple times, there were enough fumes to light that sucker up) Thank goodness for fire extinguishers!
