TKO switch to an Auto
Old Dec 12, 2005 | 01:08 AM
chriscindy6369's Avatar
chriscindy6369
Default TKO switch to an Auto
I have a 94 gt with a tko-500 i want to go to a auto. Any idea on what i need to change? and where to get all i need..I'll sell my stuff to help pay for the new set up
Old Dec 12, 2005 | 11:57 AM
doc_phibz's Avatar
doc_phibz
Default RE: TKO switch to an Auto
could i ask, why? and how much u want for the TKO?
Old Dec 12, 2005 | 12:22 PM
Tim37's Avatar
Tim37
what auto do ya want to use.
a c4 or c6 all you need is the tranny and shifter and maybe driver shaft.. a hurst or b&m or other shifter you can get form summit or jegs.
Old Dec 12, 2005 | 05:04 PM
waxyourboard's Avatar
waxyourboard
I'll trade you my AOD setup for your TKO 500 setup =)
It's something along the lines of:
Crossmember, driveshaft, flex plate, shifter, you're going to probably want a trans cooler ran and mounted, and i'm not sure if you're going to need a new computer... i know for the auto-to-manual swap you dont, but i'm not sure if you do for the manual to auto.
You can either keep or exchange your pedal setup, and that's all i can think of right now.
Old Dec 12, 2005 | 05:56 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
wow, i have never heard of that swap. It all seems backward to me LOL.
These guys have it covered. It should not be that complicated on a 94.
You will probably want an automatic pedal assembly as well (not much point in keeping the clutch pedal) but you could get that from the boneyard.
Old Dec 12, 2005 | 06:52 PM
RacerX's Avatar
RacerX
watch out SHARKs in the waters!!!
Old Dec 12, 2005 | 10:44 PM
chriscindy6369
I want to switch cause i'm tired of 5 speeds. I want to run a Auto with a stall conv and transbrake. I have in mind another Motor for the car. I have reciept's for the tko-500 and bell housing,aluminum driveshaft/steel billet flywheel and everything else. Total cost was $ 2,468.00 I bought all this on 5-19-04. If i come across what i need to put in the car i'll sell everything for $ 1,700
Old Dec 13, 2005 | 02:05 PM
C/Note's Avatar
C/Note
I ♥ Acer
ORIGINAL: chriscindy6369
YOU THINK IT WILL HOLD UP TO MY NEW MOTOR BBC 489 8-71 BLOWER.??
Old Dec 13, 2005 | 02:29 PM
Tim37's Avatar
Tim37
ORIGINAL: C/Note
it will hold fine as long as you don't install thedrive shaft.
Old Dec 13, 2005 | 10:10 PM
chriscindy6369
It will hold 500+ of Tq. The driveshaft i wouldn't probably use but i know someone using the same driveshaft in his mustang thats runs 9.13's . but every application is different
