Differential Bad?
Old Dec 14, 2005 | 08:13 PM
95_302_StangMan's Avatar
95_302_StangMan
Default Differential Bad?
Hey. My car is makeing a loud low howling noise. It sounds like its coming from the back end. I think it might be my rear differential. I think its that because when I bought the car last May and while driving it home the tire blew out. So we put on the spare donut tire and drove 200 miles home. My dad was driving and he was going around 70 for a while. It did not make this noise after and it did not seem to make it until a couple mounths ago. It just seems to keep getting louder and louder. There is no vibration and it is speed not rpm or gear related. I have checked the transmission fluid the rear end fluid and the the u joint all seem to be in good condition. There seems to be very little play with the driveshaft. I jacked up the rear end and the wheels do not whiggle. When I drive it while on the jacks it makes no sound(went up to 40mph). There was plenty fluid in the rear end, and it seemed that the transmision had more than enough. It is not the tires because while driving on snow and ice or gravel the sound does not change. Please let me know what you think the problem could be. My dad says we should "wait until whatever it is breaks then we will know what is wrong." But I dont think that is the best idea, also it is super annoying and I can hardley hear my radio. I have described it as best as possible. Thanks
Old Dec 14, 2005 | 09:22 PM
waxyourboard's Avatar
waxyourboard
Default RE: Differential Bad?
Either rear end or wheel bearings. Get a shop to check it out and tell you (usually they'll do it for free)
Old Dec 15, 2005 | 12:13 AM
kartracer55's Avatar
kartracer55
Ive got 1$ that says its the carrier bearings. Had the same problem with the durango, around 60k. Yes, it is an expensive fix, luckily it was under warranty.
Jim
Old Dec 15, 2005 | 12:39 AM
03YellowPony's Avatar
03YellowPony
ORIGINAL: 95_302_StangMan
Usually Dad's are good for info. In this case DON'T listen to him. Right now, it may be just a bearing. How would you like to end up replacing an axel, or the entire rear end if it explodes? Get it fixed as soon as possible. You may end up actually saving $$$ in the long run.
Old Dec 15, 2005 | 01:42 AM
skylark494's Avatar
skylark494
Driving with the donut for that long was bad. The donut was turning that axle faster than that of the tire on the opposite axle. Next time call AAA or find the nearest tire shop if going long distances. Its ok to run on the front for a longer period of time.
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
GLOCKer
Sep 28, 2015 07:36 AM
