Rear End
Old Dec 18, 2005 | 08:45 PM
Geofferson's Avatar
Geofferson
Default Rear End
What would be a good street rear end to run with a 5.8L 5spd.
Old Dec 18, 2005 | 08:47 PM
BlackSVTsnake302's Avatar
BlackSVTsnake302
Default RE: Rear End
8.8
Old Dec 18, 2005 | 09:07 PM
waxyourboard's Avatar
waxyourboard
Depends, what kind of car do you have and what kind of tires are you running?
If you're running wal-mart specials, you could go with a 7.25 and not break anything
If you plan on getting any sort of traction, go with either 8.8 or a 9. And i suggest an LSD or locker
Old Dec 19, 2005 | 12:05 AM
downwardspiral's Avatar
downwardspiral
9" with 4.11's, limited slip and 31 spline axels. Someone is going to tell me I'm wrong, but I'm not. It will be bulletproof and relativly cheap. you just can't beat the 9". There is a reason chevy guys use it when they make serious power.
Old Dec 19, 2005 | 12:38 AM
MCFAST's Avatar
MCFAST
ORIGINAL: downwardspiral
+1
Old Dec 19, 2005 | 04:22 AM
waxyourboard
Are you running a classic car or a newer 80's or 90's stang? If you're running classic, definitely go for the 9", but if you're running an 80's or 90's the 8.8 will be more than enough to handle it. There's going to be no way you're going to break that running street tires or even drag radials.
And as for the 4.11s it really all depends on what size tire you have, what tranny you're running (3, 4, or 5sp) and what you're looking to use the car for.
Old Dec 19, 2005 | 08:03 PM
Geofferson's Avatar
Geofferson
Im running an 84 5.8 5spd. im gonna have 16" wheels in the back and 15" in the front. im gonna have show tires(Radial T/A) and im gonna be usin it to cruise with no major racing. what would be a good rear end for street and racing purposos.
Old Dec 19, 2005 | 10:40 PM
waxyourboard
An 8.8 will do you fine
Old Dec 20, 2005 | 12:16 PM
downwardspiral
Am I the only one that needs everything in excess? I always hear people saying the 8.8 should be fine.. can someone explain this to me? If you are changing the whole rear, shouldnt you go with the best? It just seems dumb to me to spend all that money for "good" when you can get something better for a few bucks more.
Old Dec 20, 2005 | 05:07 PM
waxyourboard
Because you can get an 8.8 rear end with disc brakes for somewhere around $300, maybe even less depending on who you buy it from, and it will bolt directly into your car, no modification needed whatsoever, you can buy a stock driveshaft, get all stock parts, very simple.
Why not get a 9"? For one, it weighs more, robs more power, probably has the same spline axles, and probably won't mount up using stock parts, and a new driveshaft will probably be needed. Brake lines may also be different sizes
Why not get a built 9"? You could get and install at least two stock 8.8s for a used piece, and running street tires, there's really no need for it on street tires or even drag radials.
The 8.8's a direct fit, more modern design, less lossy, weighs less, and only two tenths of an inch smaller than a 9"
If you use that logic, you'd end up with the ferarri of rear ends in no time (I could go for a stock used 8.8, but a new 8.8 is only $200 more, ooh, but a used 9" is the same price, but a used built 9" is only $200 more than that, but a new built 9" is only $200 more than that, but the 35 spline axles are only $200 more) Yeah i know i'm exaggerating and kinda went off on a tangent, sorry, but still not on slicks, you're not gonna break an 8.8 esp with a torque monster like the 5.8
