I just installed a AFE CAI..
Old Dec 26, 2005 | 05:59 PM
Phillips1847's Avatar
Phillips1847
Default I just installed a AFE CAI..
And my check engine light is now on... If any of you can take a look at these pictures if you see anything wrong with my work. Should I just wait it out to see if the light goes out? Or is there something I need to do?
Old Dec 26, 2005 | 06:12 PM
ByPopularDemand's Avatar
ByPopularDemand
Default RE: I just installed a AFE CAI..
It looks ok from what I see did you reconnect the MAF? Did it have an extra hole to be plugged like the MAC ones do.
Old Dec 26, 2005 | 08:06 PM
Phillips1847
Yes the MAF sensor was reconnected. But the check engine light is still on.
Old Dec 26, 2005 | 08:11 PM
84Notch's Avatar
84Notch
you got good connection to MAF? double check to make sure.all clamps sealed tight to prevent vacuum if that may cause trouble code?
Old Dec 26, 2005 | 11:28 PM
sandcracker21's Avatar
sandcracker21
do u have a tool that can scan error codes?
Old Dec 27, 2005 | 03:17 AM
Phillips1847
I personally do not, but my schools shop does. But, no school for a while.
Old Dec 27, 2005 | 03:56 AM
Phillips1847
Fixed it. I just disconnected the batery, loosened everything and tightened them taking my time and making sure everything was perfect. I then put the MAF in checking all of the wires and electrical tape making sure it was tight. Then I connected the batery and took the car for a 20 or so minute test drive. The light hasn't been on since and I hope it stays that way. Thx all for your help
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
