need some help
Old Jan 5, 2006 | 05:39 PM
95GreenMachine's Avatar
95GreenMachine
Default need some help
I have a 95 automatic gt stock...... I want to do some a few engine and transmission upgrades.... I want to upgrade the transmission to a 4R70W... For the engine i want to go with a 331 stoker kit..... I need to know what other things i need to do with theses upgrades such as what kind of block, heads, and so on.
thanks
Old Jan 5, 2006 | 05:44 PM
Tim37's Avatar
Tim37
Default RE: need some help
well we need some numbers the stock block is good upto abotu 400 hp then i would go with a sportsman block up to about 1000 then on to a man-o-war block. again with the heads i would start with a set of gt40 for a mild engine then afr then on to maybe a set of brodix or yates heads.
Old Jan 6, 2006 | 05:48 AM
95GreenMachine
i want go about 300-325 rwhp and near the same in torque
Old Jan 7, 2006 | 01:15 AM
P.S.I.cho's Avatar
P.S.I.cho
well just use the stock block bore and stroke coasthigh.com has a kit you can buy wich has crankshaft, connecting rods, pistons, wrist pins, rings, and rod and main bearings. for heads you dont need anything special but personally i like the edelbrock heads
