Brake light
Old Jan 27, 2006 | 11:25 PM
ByPopularDemand's Avatar
ByPopularDemand
Default Brake light
I have a 2000 V6, and when I gun it from a stop the brake light flashes on. It also pops on occasionally when I go over a dip or speed bump.
Old Jan 28, 2006 | 12:59 AM
pete1665's Avatar
pete1665
Default RE: Brake light
Your brake fluid is low. Fill 'er up to the line and no more problems!
Old Jan 28, 2006 | 02:06 AM
alexr's Avatar
alexr
also you might want to replace your blinker fluid
Old Jan 28, 2006 | 02:09 AM
nelson95's Avatar
nelson95
or maybe the bulb is loose
Old Jan 30, 2006 | 03:40 AM
cobradaddy's Avatar
cobradaddy
sounds like you have a short.
Old Jan 30, 2006 | 12:41 PM
ByPopularDemand
I changed the brake fluid and havent seen the light
Old Jan 30, 2006 | 05:41 PM
xRockThePonyx's Avatar
xRockThePonyx
I had the same problem in my 00 v6 and my back brakes were bad. I had to replace the rotors and everything. The mechanic told me that the light was coming on because my back brakes were SO badly worn that if I waited much longer, it could have been really bad.
I would advise checking that out for sure, because it could be the same thing.
Old Jan 30, 2006 | 05:50 PM
pete1665's Avatar
pete1665
ORIGINAL: xRockThePonyx
the only thing the brake light tells you is that your're braske fluid is low... it doesnt say you have bad brakes.although they could have been so worn that they required more fluid to push them farther in.
Old Jan 30, 2006 | 05:57 PM
xRockThePonyx
Well, it had something to do with it, because that's what made the guy check all my brakes and whatnot.
If he's got a 2000, and hasn't checked his back brakes, he probably should because he's likely to need them pretty soon anyways.
Old Jan 30, 2006 | 06:17 PM
Tim37's Avatar
Tim37
what can happen if you never fill the break fluid as your pads wear the resivoir becomes lower because more fluid is staying in the caliper (its suposed to do that) when you get to a low enough level the light comes on because the fluid is low in the resiviour. i would gohead and check out the pads see if you need a break job.
