93 5.0 conv. tachometer sticking
Old Feb 9, 2006 | 04:39 PM
cletusboyer's Avatar
cletusboyer
Default 93 5.0 conv. tachometer sticking
My 93 LX 5.0 has 162K miles on it and the tachometer sticks at 3,000 RPM unless I exceed that RPM. Does it more when it is cold. I spoke with a friend who has a 92 with 160K on it and she has the exact same problem, lives in another part of the country. Anybody else have that problem? Know what I should do to fix? My first time here. Thanks for the help.
Old Feb 10, 2006 | 12:01 AM
roadrunner's Avatar
roadrunner
Default RE: 93 5.0 conv. tachometer sticking
Get an aftermarket tach
Old Feb 10, 2006 | 12:41 AM
ShadowDrake's Avatar
ShadowDrake
Well, if you pull out your speedometer cluster, you should be able to take a fork or something and pry the needle up a LITTLE bit (EDIT: from the center)... but this will only help if the needle is getting stuck on the backing... look at it closely when it gets stuck, and if the needle is just contacting the back, pulling it up will fix it.
mustang0291
Oct 12, 2015 07:55 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
BeatnikFink
Oct 1, 2015 08:00 PM
wraith777
Sep 28, 2015 10:49 AM
