Need to know if its true!!
Old Feb 11, 2006 | 04:37 PM
Stang562's Avatar
Stang562
Default Need to know if its true!!
well I was on ebay looking for performance parts and I wanted to know if these ground wires really work like they say
http://cgi.ebay.com/ebaymotors/94-98...QQcmdZViewItem
it says it improves performance
is this true? does anyone have this?
thanks
Old Feb 11, 2006 | 04:45 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Need to know if its true!!
Save your money!
Old Feb 11, 2006 | 04:52 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Gimmick alert. Yes you need a good ground but that will not get any hp.
Old Feb 11, 2006 | 04:57 PM
alexr's Avatar
alexr
if you wanna gain/save hp via your electrical system, convert the electrical system to 24 or 48 volts. higher voltage means lower amperage, and lower amperage means smaller wire required to keep from overheating. which all in all, smaller wire, less weight, boom weight reduction. it may sound crazy and may not be really worth it, but its been proven and many pro racers do it... but i wouldnt unless you know what youre doing.
Old Feb 11, 2006 | 05:02 PM
Stang562's Avatar
Stang562
if thats true ^^ how or what do you need to convert to 24 or 48 volts?
Old Feb 11, 2006 | 05:34 PM
Tim37's Avatar
Tim37
ORIGINAL: ARdoller
I*V=P
what you said is true you would get less heat loss in the electrial system you would also be able to run smaller gauger wire making it lighter but P=P no mater what its gonna take the same hp from the engine to make that same power.
btw if any one is thinking about it don't it would cost you so much more to set everything up than ist worth.
Old Feb 11, 2006 | 06:08 PM
TBird232ci's Avatar
TBird232ci
The only way youll feel any power is if your grounds are in horrible condition to start with, and your car isnt getting the power it needs to the ignitions system. Save the money, buy a little bit of dilectric grease, find every ground, clean it up with some sand paper, put a dab of grease on it, and be done.
Old Feb 11, 2006 | 10:58 PM
alexr's Avatar
alexr
ORIGINAL: Stang562
well you would need smaller gauge wire, id ask a professional about which specific gauge, prob 18, and you'd need a 24 or 48V battery, and AC to AC inverter to step-down the voltage from 24/48 to 12 for certain electronics that need higher amperage.
all in all its a lot of work, and unless youre gonna have it professionally done, its not worth it.
Old Feb 12, 2006 | 12:36 AM
03YellowPony's Avatar
03YellowPony
[sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif]
Does that answer your question?
Old Feb 12, 2006 | 03:00 AM
alexr's Avatar
alexr
ORIGINAL: 03YellowPony
whats so funny? are you on drugs?
