sway bar bushing
Old Feb 12, 2006 | 01:38 AM
blkgt50's Avatar
blkgt50
Default sway bar bushing
I want to get sway bar bushing for my 88 LX 50. I already have the end links all I need is the ones that hold the bar to the frame. I have gone to Energy Suspension web site to look for them and they have several different size one and not sure which one I need. I still have the stock sway bar. I'm sure someone has replace them before I just hope that you have the part number and are willing to give it to me so that I can get them thank for the help.
Old Feb 12, 2006 | 01:42 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: sway bar bushing
If you have a caliper just measure the thickness.
Old Feb 12, 2006 | 09:59 AM
blkgt50's Avatar
blkgt50
Did you say measure the thickness of a caliper? How is measuring a caliper going to give me the thickness of a waybar?
Old Feb 12, 2006 | 10:52 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: blkgt50
Hahahahahah!!! NO, use a caliper to measure the thickness of the swaybar. You know(well maybe not) one of these!!
Old Feb 12, 2006 | 08:39 PM
blkgt50's Avatar
blkgt50
Ok, yes i'm an idiot. I thought you meant the brake caliper. I could do that but just thought that maybe someone may have the part number from when they bought theres and could just get ther number. I will just have to go to a speed shop and ask them for the part number. Thanks ....
Old Feb 12, 2006 | 09:18 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: blkgt50
LOL!! NP man, good luck!
Old Feb 13, 2006 | 08:22 PM
blkgt50's Avatar
blkgt50
Hey PRO50SC that's one nice coupe you have there. What you got in it? I also have a coupe an 88 coupe to be exact. You see the list on my signature what I have. I also have 200k on the clock with a stock motor. I want to get a new motor but want to do all the suspension and brakes first then worry about the motor and trans (which I hope to get a T-56).
Old Feb 13, 2006 | 09:15 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: blkgt50
https://mustangforums.com/fb.asp?m=1024059
List of mods.
Hurst shorty shifter
H pipe
Mac 2.5" cat back w/ 3.5" stainless tips
3:73 Ford racing gears
Autometer gauges
Autometer Phantom Monster Tach/shiftlight
Lightning audio amp and 10" subs in custom sub box
Sony cd head unit
Cervini's cobra r hood and factory style wing
Ford Racing 17 x 8 crome bullitts
Kumo 245/45/17 tires on front
17 x 9 Bullits w/ 275/40/17 Nitto dr's on rear
MSD 6al ignition system
MSD dist. cap
MSD Boost timing retard module
Crane fireball ps 91 coil
Ford Racing 9mm ignition wires
ATI Procharger 14lb boost w/ 3 core intercooler
Polished PA Proformance 3G 130 amp alternator
255lph Holley in tank fuel pump
Canton Racing aluminum overflow tank
Professional Products Typhoon polished intake, 70 mm throttle body and egr plate
2 core aluminum radiator
Ford Racing polished aluminum valve covers
Misc. chrome parts for underhood accessories
Battery relocate
Custom billet battery tray
Optima red top battery
BBK cold air intake
ARF 17x9 chrome bullitts w/ 275/45/17 Nitto drag radials
FMS 30# injectors
C&L 76mm mass air
Kirban AFPR
Mac upper and lower control arms
Sub frame connectors
2003 front Pony seats
BBK ceramic equal length shorties
150K on stock block, heads and cam.
flash_xx
Oct 16, 2015 07:23 AM
Explosive
Oct 2, 2015 07:45 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
UrS4
Sep 30, 2015 10:13 AM
