Vent Problem
Old Feb 15, 2006 | 07:38 PM
RawGtPower's Avatar
RawGtPower
Default Vent Problem
I have a 94 gt. Just recently my heater/air blower, stopped blowing out of any of the vents except for the defrost. I only get air or heat out of the front window defrost, no matter what setting it is on. Any help would be appreciated.
Old Feb 15, 2006 | 07:43 PM
Tim37's Avatar
Tim37
Default RE: Vent Problem
sounds like a vacume problem.
Old Feb 15, 2006 | 07:45 PM
RawGtPower's Avatar
RawGtPower
Yeah. Im just nervous on tearing apart my dash and not knowing what to look for. I know if i take it to a shop, theyre going to rape me with labor alone.
Old Feb 15, 2006 | 07:51 PM
Tim37's Avatar
Tim37
check your vacume hoses under the hood you may have one cracked if there is you will need ot replace it any way just so your perfomance doesn't go down.
Old Feb 15, 2006 | 07:54 PM
RawGtPower's Avatar
RawGtPower
ill have to check that tomorrow. Supposed to get 60 degree weather here in michigan, perfect weather to pull the car out
Old Feb 15, 2006 | 07:56 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Have you done any recent work to the car? Possibly you knocked the vacuum supply line off. I've seen it happen.
Old Feb 15, 2006 | 08:05 PM
RawGtPower's Avatar
RawGtPower
the most recent work, was replacing the battery. I was just pulling into my sub and i went to turn the air on, and no matter what setting i put it on, it would only blow out the defrost. I do recall installing my X pipe and tightening my header bolts a month or so before this occurance. Where would this hose be located at.
Old Feb 15, 2006 | 08:44 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Not sure on a 95, just look around at the vacuum line and make sure everything is connected. The problem you have is most likely a supply problem.
Old Feb 15, 2006 | 08:53 PM
ShadowDrake's Avatar
ShadowDrake
ORIGINAL: RawGtPower
Say WHAT!? It was 40 today, at the most. Tomorrow it's supposed to freeze again.
It is very likely a vacuum problem. I can look on my friend's 94 GT next time I get the chance.
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Beerman309
Sep 19, 2015 01:16 AM
tmdm
Sep 4, 2015 06:45 PM
