extreme idle
Old Feb 21, 2006 | 03:06 PM
ozzysstang's Avatar
ozzysstang
Default extreme idle
I recently baught a 1995 mustang convertable with a 3.8 V6, it is idling at about 2100 and no codes are showing up when tested, does any one have any ideas? Thank you
Old Feb 21, 2006 | 04:16 PM
monkeydude3's Avatar
monkeydude3
Default RE: extreme idle
sounds like you have one of two things. Either A a huge vacuum leak (which would probably set a code) Or your Idle air control valve is sticking. It is very close to or on the throttle body. Try tapping on it with a screw driver, and if that doesn't help try taking it off, apart, clean it and put it back on. I've heard a lot about these having idle issues due to the IAC.
George
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
MacSerio
Sep 27, 2015 01:05 PM
