Drop Question
Old Feb 13, 2004 | 11:46 PM
Krusher's Avatar
Krusher
Default Drop Question
Next project, lowering......</P>
Where and how much. I want blue power coat springs and the drops:</P>
Front: 1.5-1.75</P>
Rear: 1</P>
EDIT: so as not to post *****... I will comment about the statement below:</P>
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA</P><edited><editID>Krusher</editID><editDate>38031.5417013889</editDate></edited>
Old Feb 14, 2004 | 02:59 AM
N2OJunkie's Avatar
N2OJunkie
I ♥ Acer
Eibach springs...........Prokit
Old Feb 14, 2004 | 02:37 PM
04ShakinSteed's Avatar
04ShakinSteed
I ♥ Acer
</P>
The only way to go....I agree.</P>
"And get a off road x-pipe and magna cat backs and cut them out and put spintechs in......."</P>
<FONT size=4>LMAO!!!!!!</FONT></P>
Old Feb 14, 2004 | 08:38 PM
mkspeed26's Avatar
mkspeed26
if you go any more than 2 you will need c/c plates, fyi. there are many companies out there that sell springs. i say get whichever gives you the right stance and the best price. if it is close to eibachs in price, then get the eibachs because they are definatley a great product.
Old Feb 15, 2004 | 12:24 AM
stang574's Avatar
stang574
I agree not to go any lower than that. You will get into bumpsteer and chamber problems if you do. Try to get a spring that doesn’t have a high spring rate, otherwise you'll regret it.
Old Feb 15, 2004 | 05:53 PM
JHonor's Avatar
JHonor
I agree. Especially if you frive on the street regularly. Springs that are 2 inches and really stiff are hard to deal with; trust me, I've been there. Eibachs and Steedas will give you the stance and performance you're looking for.
Old Feb 15, 2004 | 06:05 PM
mkspeed26's Avatar
mkspeed26
the stiffer the better for handling. stangs werent made for a caddy ride <IMG src=smileys/smiley2.gif border="0">
Old Feb 16, 2004 | 03:43 PM
351CLVD's Avatar
351CLVD
Default 1973 Suspension..
Fairly new to building mustang for strip. Question: What size/type of springs and shocks should I use for optimum performance on strip. Not worried about driveability or street use.
Facts: 1973 Mach I 351C approx 375hp to flywheel, 260-280hp to rearwheel, only interior remaining are seats (dash, carpet, insulation, backseats, all plastic panels..gone), cheap slapper bars in place on rear leafs, 9 in. rearend 370 gears, 14 inch wheels front and back, C-6 with 2500 stall, 750 holley, ported 2vheads, alum roller rockers, new kb flat-top, new cam, ... motor built to 2,500-6,000 RPM.
Probably more info than required, Thanks, Seth
robcy
Suspension
Oct 27, 2015 11:14 PM
Gene K
Oct 21, 2015 11:37 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
zanemoseley
Sep 6, 2015 12:58 PM
