Heater only blows from defroster
Old Feb 27, 2006 | 03:34 PM
GaryS's Avatar
GaryS
Default Heater only blows from defroster
Re. 97 base engine: I posted this a while back but now I am ready to tackle this issue. Has anyone replaced the selector switch on the center console? Not the temp control, the other one on the right that controls where the air is coming from.
I suspect that this is the issue since I cannot get any airflow down to my feet. I know that this unit is vacuum controlled but there isn't any loss of vacuum so I doubt that this is the cause.
Other than the Ford dealer, does anyone have a good source for this switch? Anyone have a good used one?
Thanks,
Gary
Old Feb 27, 2006 | 03:40 PM
Chopper's Avatar
Chopper
Default RE: Heater only blows from defroster
These vacuum lines can get clogged so make sure you have vacuum getting to the controller.
Old Mar 1, 2006 | 08:52 AM
ikeybmg's Avatar
ikeybmg
yea this happened to me and it was a very small vacuum hose and i coundnt even tell i was losing vacuum
Old Mar 1, 2006 | 10:04 PM
GaryS's Avatar
GaryS
thanks for the replies. I had the center console all the way disassembled, down to the switch and I attempted to test the vacuum lines to the switch. I used my standard engine vacuum tester and could not find vacuum at the spaghetti lines going to the switch. Did either of you test the actual very small vacuum lines going to the switch?
Any testing ideas? I have an engine vacuum tester as well as a Mity Vac hand pump.
Gary
Old Mar 2, 2006 | 04:02 AM
ikeybmg's Avatar
ikeybmg
nah,i just happened to find mine loose, i had just had the new motor put in and when i got it back i didnt have heat anywhere except for the windshield. mr and a friend was looking at the motor when i noticed it loose. it was near the firewall on the passenger side. very small one and it didnt make noise or anything. but when i plugged it up i had heat. maybe you could just glance through the small lines up there near the firewall. good luck
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sixer4Life
Sep 29, 2015 07:03 PM
cbird1177711
Sep 2, 2015 04:12 PM
