Rear Tires
Old Apr 7, 2006 | 10:47 PM
praztek's Avatar
praztek
Default Rear Tires
Any suggestions on replacement rear tires, that have the same sidewall "50" height? Wanted to keep the same height as the oem fronts, but wanted to go wider in the rear.
Current 235/50/ZR18 Bridgestone all around.
Thanks
Old Apr 7, 2006 | 10:50 PM
lilc1511's Avatar
lilc1511
Default RE: Rear Tires
eagle F1 gsd3s.... my favorite tires
chris
Old Apr 7, 2006 | 10:57 PM
praztek's Avatar
praztek
Have you found them with the 50 sidewall height? Looking for same sidewall height as the fronts, but just wider.
Old Apr 7, 2006 | 11:08 PM
Menace's Avatar
Menace
The wider the tire, the lower the sidewall is going to be. For your 235/50... That means your sidewall is 50% the width of your tire. So if you go a wider tire, it's going to be a smaller percentage.
Here is a good way to calculate things.
Example tire.
275/40/18
275 divided by 25.4 = 10.83 Rounded. (Meaning your tire is 10.83 inches wide.)
10.83 multiplied by 40% = 4.33 (The height of your sidewall in inches.)
4.33 multiplied by 2, plus the size of your wheel (18) = 26.7 inches. (Tire height.)
Stock tire
235/50/18
235 divided by 25.4 = 9.25
9.25 multipled by 50% = 4.625
4.625 multipled by 2, plus the size of your wheel (18) = 27.25.
The end result, the wider tire is smaller in height then your stock tire. So what you need to do is calculate various tire sizes and find the best one that matches your stock heigh, if that is what you want.
Hope this helps.
-Menace.
Old Apr 8, 2006 | 11:37 AM
ratzila's Avatar
ratzila
Try this tire size calculator http://www.miata.net/garage/tirecalc.html
Old Apr 8, 2006 | 11:53 AM
randy78045's Avatar
randy78045
ORIGINAL: Menace
Example tire.
275/40/18
Stock tire
235/50/18
Hope this helps.
-Menace.
Damn, you should consider teaching... I almost understood that..
Old Apr 8, 2006 | 02:55 PM
Nautique's Avatar
Nautique
Menace,
I'm not a tire expert but the statement you made as to "the wider the tire, the lower the sidewall is going to be" cannot be correct. If you stay in the same series, say 40 for example, 40% of a larger number is always greater than a smaller number, so the wider the tire, the taller the tire (more sidewall). In the example you gave, Praxtec would need a 295/40/18 to get the same height (very close) to the 50 series he has in front. Thats assuming that Bridgestone makes a 295/40/18 in the same tire & tread pattern.
4.625/.4=11.56(needed width in 40 series) 11.56*25.4=293.6 tire size needed in 40 series
If my thinking is wrong, I am sure I will be corrected.
Old Apr 8, 2006 | 03:07 PM
Menace's Avatar
Menace
No, it isn't the case in all aspects. Though I was just trying to make clear to Praztek that if he went with a wider tire, and trying to find the same 50% Sidewall that his skinner tire had, that they wouldn't be the same height. Meaning, he would have to look for the tires he wants, and then calculate them using the method I provided to find a tire that had a height the same as stock. Make sense?
Sorry for the confusion,
Menace.
mtgldr
Feb 3, 2024 09:00 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Sep 8, 2015 11:50 AM
M3hunter
Sep 5, 2015 03:42 PM
Sep 1, 2015 08:16 PM
