idle 'learning' ?
Old May 23, 2006 | 05:27 PM
05gtrules's Avatar
05gtrules
Default idle 'learning' ?
I was going through the manual and noticed that it says when you disconnect the battery, after you re-connect, to let it idle for 10 min or so to re-learn it's ideal idle point. how important is this? After i installed my intake, I didn't do that after re-connecting the battery. I noticed when I start the car, it idles high, and quickly comes down to a lower idle... If i want to re-do that process, can i just disconnect the battery and let it idle after reconnecting? can i only disconnect one of the cables (pos or neg)? is a re-tune necessary after this ? thanks...
Old May 24, 2006 | 02:22 AM
GGIII's Avatar
GGIII
Default RE: idle 'learning' ?
Yeah. This should also be done after retuning, since that clears the CPU... But I don't do it.
Perhaps this is why my IACV is going bad?
Old May 24, 2006 | 01:22 PM
05gtrules's Avatar
05gtrules
ok, dumb quesiton, but what is the IACV and how do you know it's going bad? maybe I should do that procedure tonight??
Old May 24, 2006 | 02:08 PM
GGIII's Avatar
GGIII
Default Re
Idle Air Control Valve
Just determines the idle of the car. I've been throwing an engine code because my car doesn't idle properly. The suspect is a bad MAF or IACV
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
Yantorno
Sep 30, 2015 10:29 AM
MacSerio
Sep 27, 2015 01:05 PM
