LCA install
Old Jun 11, 2006 | 06:00 AM
Timmay!!!'s Avatar
Timmay!!!
Default LCA install
I was under my car the other day and I noticed there is a brake line routed through the LCAs or at least the left one. Does changing these out entail a brake bleed or is there a simple way around this?
Old Jun 11, 2006 | 09:35 AM
RICVA05's Avatar
RICVA05
Default RE: LCA install
If you are not planning on putting the stocked LCA'S back on as I was just cut a notch out of them so you don't have to waste time with the emergency brakes. It funny how fast a band saw can take care of that problem.
Old Jun 11, 2006 | 10:45 AM
hawgman's Avatar
hawgman
I ♥ Acer
Is it a brake line or a brake cable? You shouldn't have a brake line running through your LCAs. The emergency brake cable runs through them though. That is no big deal.
Old Jun 11, 2006 | 12:22 PM
F00Mustang's Avatar
F00Mustang
the cable realeases easily at the brake caliper.
Take the rear wheels off b/c it makes the cable much more accessable. And don't forget to release the parking brake.
Old Jun 11, 2006 | 12:46 PM
MusiccityGT's Avatar
MusiccityGT
ORIGINAL: F00Mustang
Exactly! It is VERY easy to remove the parking brake cable. One simple clip. If you have the car in the air high enough, you don't have to remove the tires to get to them. Simply reconnect them and then use a zip tie to secure them to the new LCA's or you will hear the cables hitting the LCA'S over bumps.
Old Jun 11, 2006 | 07:50 PM
Sleeper05's Avatar
Sleeper05
+1
its the e-brake cable...no bleed is necessary. just zip-tie the line to the new lca so its not hanging too low or anything
Old Jun 11, 2006 | 09:29 PM
Timmay!!!'s Avatar
Timmay!!!
Thank for the enlightment. I never thought it would just be the e-brake cable.
Old Jun 11, 2006 | 09:47 PM
05BlackPony's Avatar
05BlackPony
Or you could give these LCA's a try.. built in cable retainer
http://www.cheperformance.com/cartge...pid=162&cid=15
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
