lca from bmr/steeda/ diff
Old Jul 3, 2006 | 09:21 PM
Vidgomd's Avatar
Vidgomd
Default lca from bmr/steeda/ diff
what the diff between the recular lca's or rod ends..
bmr has rear lca's with poly bush,
also has
rear lca's with rod ends
also
rear lca's with combo poly bush and rod ends
what should i get and if i get the regular lca what can i expect from them.
Old Jul 3, 2006 | 11:43 PM
06GT4RAD's Avatar
06GT4RAD
Default RE: lca from bmr/steeda/ diff
Get the one with the Poly Bushings if your car is driven daily. The ones with the Spheircal ends will be noisy.
Richard
Old Jul 4, 2006 | 12:35 AM
CrazyAl's Avatar
CrazyAl
Rod ends are stiffer than the Poly bushings. The downside, like GT4RAD said is that the rod ends give a harsher ride and will transfer more road noise into your car.
So, the heirarchy goes like this:
Stiff: poly-poly (street use)
Stiffer: poly-rodend (compromise)
Stiffest: rodend-rodend (race only)
If you are lowering your car, consider adjustable control arms so you can get your pinion angle right.
Old Jul 4, 2006 | 04:15 AM
Vidgomd's Avatar
Vidgomd
who makes adjustable ones and where can i get them and cost??
Old Jul 4, 2006 | 11:49 AM
CrazyAl's Avatar
CrazyAl
BMR and Spohn both make adjustable LCAs. They cost a little more than the non-adjustable versions.
You can get them directly from those companies, or from many aftermarket dealers. Look at the forum sponsor list. LMP Performance carries both.
Old Apr 11, 2007 | 11:06 AM
My05GT's Avatar
My05GT
I know this is an old thread but I figured I'd post my ? here. I bought the Spohn adjustable LCAs with the poly bushings. They seem awful noisy. My car sounds like a rent-a-wreck creeking and what not at low speeds. Any way to get rid of this noise? I'm ready to switch back to the stocks ones.
Also, what is the correct pinion angle? I put the LCAs on myself, but don't know what or how to adjust the angle.
Thanks!
Old Apr 11, 2007 | 12:03 PM
Boostaddict's Avatar
Boostaddict
Former Sponsor
Just to let you guys know if you're thinking of going the BMR route we still have a 5% off special going on.. Just put in coupon code: LETHALBMR at checkout and the 5% will be deducted from the order. If you want to call the order in thats not a problem just mention the discount and you'll still get it over the phone..
In regards to the Steeda stuff we have all their stuff in stock and if you're looking to go that route call us and we'll be glad to give you a quote on whatever you're looking for.
We look forward to assisting you. Thanks, Jared
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
67LimeCoupe
Sep 30, 2015 04:46 PM
UrS4
Sep 30, 2015 10:13 AM
Sep 1, 2015 08:16 PM
