engine whistle
Old Jul 19, 2006 | 08:19 PM
godfather_go3's Avatar
godfather_go3
Default engine whistle
Been back to the dealer and he says nothing wrong, here's the situation, I have a 06 GT, if I get on it in first gear at about 15 mph I start to hear a whistle, it will in crease in pitch till I hit second, after a second or two in second gear the whistle comes back and the pitch rises again. to me I thought maybe a vacuum leak of some kind, however, my dealer says everthing is normal. The sound is not over powering but with the shaker 500 off it can be heard easyly. Now if the sound was from a turbo they forgot to charge me for that would be ok, but, no turbo. Does anyone else have this sound.....
Old Jul 19, 2006 | 08:52 PM
Remove_Before_Flight's Avatar
Default RE: engine whistle
Sounds like the transmission....are you getting the RPM's up before shifting.
My 05 GT does the same thing, I get on it and after 3k it starts to whistle.
I wouldn't worry bout it to much, and if something does go wrong, its still under warranty!
Old Jul 19, 2006 | 09:01 PM
godfather_go3
I should have mentioned, it has an auto trans, whistle starts about 2000 rpm when in first gear
Old Jul 19, 2006 | 09:11 PM
Hummm sorry I couldn't help ya out bub, but I have the same thing happen to but thats cause I'm usually hammering down on it when driving.
Old Jul 19, 2006 | 09:47 PM
bluepony's Avatar
bluepony
i have an 05 auto i know what youre talking about mine will do it once in a while, i cant figure out why or when as it doesnt seem to be consistent, but it does sound like a turbo so i assume its what you mentioned however it seems to run fine still so i guess you shouldnt be worried
Old Jul 22, 2006 | 06:38 PM
Berring's Avatar
Berring
Mine does the same thing that sounds kinda cool. Never thought it could be a problem??????????????
Old Jul 22, 2006 | 09:50 PM
Mizzard's Avatar
Mizzard
I have an auto also. The engine would whistle very often and didn't require much throttle to do so- sounds similar to super charger whine. Thought it was a transmission thing, but once I installed my CAI, the sound disappeared. Sort of miss it. Anyway, it's normal.
Old Jul 22, 2006 | 10:09 PM
Diabolical!'s Avatar
Diabolical!
Sounds to me like the supercharger fairy left a present under your hood! [sm=smiley20.gif]
Old Jul 23, 2006 | 12:59 AM
CrazyHorse0217's Avatar
CrazyHorse0217
My car has always done the same thing, in second or third gear (auto), before and after I supercharged it. Anybody ever had this diagnosed as a problem? It does sound cool, but I wonder if there is a vacuum leak somewhere causing horsepower loss.
Does everyone's car do this? If not, I think I will try to figure it out, since it cannot be good.
Old Jul 24, 2006 | 04:13 PM
Mizzard's Avatar
Mizzard
ORIGINAL: CrazyHorse0217
Well it makes sense you heard a whistle after you supercharged it It may just be the sound of air being pushed through the corrugated carbon filter trap after the stock filter, or just the small hole before the filter itself. Regarless, since so many people have reported this, if it were a problem there would be a TSB on it. The only HP loss is the restrictive stock intake system.
[IMG]local://upfiles/30913/CDA421A15834446298B907F2C5837F8B.jpg[/IMG]
