superchip problem
Old Aug 13, 2006 | 06:11 PM
stang05gt's Avatar
stang05gt
Default superchip problem
hi there,
I have a superchip programer and i installed Hi performance tune on my 2005 GT and when I turn on the AC the rpm goes below 500 rev and the engine goes off. Also at idle it does the same thing the engine goes off when i make any stop.By the way I am not from the U.S. and we are using here 95 octane which should ok with this tune. Do u have any suggestions.One more thing 87 ocatne works fine but the power that hi perfomance tune gives is way much better.
Thanks
Old Aug 13, 2006 | 10:51 PM
ski's Avatar
ski
Default RE: superchip problem
Increase the idle speed if the tuner has that option.
Old Aug 14, 2006 | 12:09 AM
Black06GT40324's Avatar
Black06GT40324
ORIGINAL: stang05gt
hi there,
Thanks
i would return it to stock and see if it still happens, if it doesn't . . . then the tune you have is a load of crap, need one from brenspeed, evolution, or bamachips. . .
if it does still happen, take it to the dealership and have them fix it. . .
other that that . . . prolly could check the idle rpm's on the tuner, but if it only happens when you turn on the A/C, i doubt that would be it
Old Aug 15, 2006 | 03:50 PM
stang05gt's Avatar
stang05gt
i returned the car to stock and it seems that the problem still there. I took to the dealer and i will see what will happen
thanks
Old Aug 15, 2006 | 04:12 PM
Black06GT40324
there ya go
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
