C&L Intake Installation?
Old Sep 5, 2006 | 03:18 AM
OxSMSxO's Avatar
OxSMSxO
Default C&L Intake Installation?
Did you guy's use the MAF Housing Mounting Bracket? Doesn't seem to fit very well, and sounds like it is optional.
Old Sep 5, 2006 | 03:32 AM
2006gtstick's Avatar
2006gtstick
Default RE: C&L Intake Installation?
I attempted to install the bracket on my C&L street and noticed it did'nt line up very well so I left it off. I've had my C&L for about 6 months without the bracket, and have'nt had any problems. Snug as a bug in a rug.
Old Sep 5, 2006 | 04:01 AM
RCT06GT's Avatar
RCT06GT
I didn't use the bracket as well. No problems yet, everything is kosher.
Old Sep 5, 2006 | 10:18 AM
flewbyu's Avatar
flewbyu
No bracket. No problems with not using it. Some do, some dont.
Old Sep 5, 2006 | 10:44 AM
Black06GT40324's Avatar
Black06GT40324
i used the bracket, and there is no movement whatsoever from the intake. . .
i had to modify it just a bit so i could use the factory valve cover bolt. . .
i suggest using it if you can, you don't want much if any movement from the CAI, over time, a moving CAI could fall off or slip loose which is bad.
Old Sep 5, 2006 | 10:53 AM
ski's Avatar
ski
Mine has been installed w/o the bracket for 15 months, and it's still as tight as a virgin on her honeymoon.
Old Sep 5, 2006 | 11:34 AM
3v4.6l's Avatar
3v4.6l
I didn't use bracket either and no problems, I do check it about once a month to make sure everthing is tight.
Old Sep 5, 2006 | 12:18 PM
PayDay99's Avatar
PayDay99
No bracket.
Old Sep 5, 2006 | 12:42 PM
sandyman's Avatar
sandyman
What's that?
Old Sep 5, 2006 | 12:50 PM
pegasusphototx's Avatar
pegasusphototx
ORIGINAL: sandyman
What's that?
It's like the new Camaro... a Myth! [&:]
