LCA's
Old Nov 16, 2006 | 12:30 PM
PRGT's Avatar
PRGT
Default LCA's
What is LCA's and what does they do?
Old Nov 16, 2006 | 12:56 PM
drbobvs's Avatar
drbobvs
Default RE: LCA's
Lower Control Arms. They connect the lower shock mount area of the rear axle to the chassis. In our cars, they will virtually eliminate the wheel hop from aggressive acceleration that the Mustangs are plagued with.
They are available from many manufacturers and are made of steel or aluminum. The steel are popular from BMR, CHE and others. The aluminum from Steeda seem to be popular as well. I had the BMR Steel and switched to Steeda Aluminum. The don't feel any different but they both eliminate the wheel hop and help put the power to the ground MUCH better.
Old Nov 16, 2006 | 01:26 PM
06stangGT's Avatar
06stangGT
Default RE: LCA's
did a search and came up with nothing. (i know this is a sore subject but..) Will the lca's void any part of the warrenty?
Old Nov 16, 2006 | 01:32 PM
CrazyAl's Avatar
CrazyAl
Default RE: LCA's
ORIGINAL: 06stangGT
Here we go, warranty question again....
If you read the little book that came with the car, it says that ANY mod that you make to your car voids your warranty.
On the other hand, the Magnuson-Moss law states that an auto maker CANNOT void your warranty for using Non-OEM parts, unless they PROVE that the non-standard part is what caused the problem.
In reality, it comes down to your dealer. Some dealers are OK with mods. Some dealers are not. And many are "in the middle". LCAs are probably a very "safe" mod to do, becasue even an unfriendly dealer is going to have a VERY hard time arguing that your aftermarket LCAs resulted in a problem--it just doesn't make any sense. Therefore I'd say you're probably OK warranty-wise. However, if you want to be sure, ask your dealer. If they give you a hard time about it, then just find a different dealer.
Old Nov 16, 2006 | 01:41 PM
06stangGT's Avatar
06stangGT
Default RE: LCA's
pretty sure im going to go with the BMR lca
Old Nov 16, 2006 | 02:33 PM
06hoss's Avatar
06hoss
Default RE: LCA's
ORIGINAL: CrazyAl
ORIGINAL: 06stangGT
VERY well put CrazyAl. I gotta tell you, I like reading your posts more than anybody's since you leave the BS out and just give the facts.
Old Nov 16, 2006 | 03:21 PM
bchataroo's Avatar
bchataroo
Default RE: LCA's
+1 on what 06HOSS said.
Old Nov 16, 2006 | 04:04 PM
saud alzaabi's Avatar
saud alzaabi
Default RE: LCA's
here are some pics..
Mine is an adj. BMR...
Old Nov 16, 2006 | 07:34 PM
06hoss's Avatar
06hoss
Default RE: LCA's
NICE! Saud, keep us informed though about if you get any noise from them since you have the rod end on the axle end of those.
I have some CHE adjustables still in the box, but I got delrin/poly on both ends since I wanted to make sure it stayed quiet. I've heard guys complain about the adj panhard rods with rod ends being noisy, but I'm not sure if you'll get noise with them on LCAs. Hopefully CrazyAL will weigh in here and let us know.
I never did hear if you were still waiting on that Hurst Billet shifter or not. If you are, give up man since Hurst told me that they don't know when they are going to produce that shifter. I got the steel arm Hurst on mine now and it works great. Grab a gear the short way brother!
[IMG]local://upfiles/48298/9D2A13F1C49848FCA264B7F9817CB6A7.jpg[/IMG]
Old Nov 16, 2006 | 07:42 PM
P Zero's Avatar
P Zero
Default RE: LCA's
ANy time you replace ANY suspension component, it NEEDS to be greased with SILICONE LUBRICANT. If you put it together dry, it WILL make noise. 1 more thing and probably the MOST important, when changing control arms, is you MUST set the car down on its own weight, otherwise the bushings will bind in the position theyre tightend in and literally shear the bushing from the metal its connected to, then your car will hae all sorts of weird wandering problems.
BTW, they do make aftermarlet FRONT lower control arms, I have Ford motorsport ones on mine, they made a huge difference in cornering capability. I think theyre worth more than any rear ones you get.
-P.
