GAS PUMP PROBLEM
Old Nov 22, 2006 | 05:44 PM
05Pony's Avatar
05Pony
Default GAS PUMP PROBLEM
This is prolly a repost but why in the world when im trying to fill up does the damn pump kick off like its ganna over flow. Is there somthing i can do to fix this?
Old Nov 22, 2006 | 05:52 PM
Archion's Avatar
Archion
Default RE: GAS PUMP PROBLEM
There is a tsb on it but from what i have heard its not woth it, you can try flipping the nozzle over, that works for most. I have found that on pumps that the flow is turned up it happens more, slower pumps it does not, so try slowing the pump down and it will probably go away.
Old Nov 22, 2006 | 05:54 PM
FuriousGeorge's Avatar
FuriousGeorge
I've heard the angle of the tube that extends to the gas tank causes vapor lock with tricks the pump into thinking the tank is full.
Old Nov 22, 2006 | 06:08 PM
05Pony's Avatar
05Pony
My Trans Am did that when i had it but only on one pump at this certain gas station. but this f'ing mustang does it all the time, takes me like 10-15 min to fill up sometimes.
Old Nov 22, 2006 | 06:18 PM
mlcrycc's Avatar
mlcrycc
Ya I supposidly had the TSB done, does no good. Depends upon the pump, but it's just habit now to rotate the gas nozzle 180 degrees....fills like a charm.....
Oh and looks so damn cool when you're doing it as well......
Mike
Old Nov 22, 2006 | 08:17 PM
TPony's Avatar
TPony
ORIGINAL: mlcrycc
Mike
That's exactly what I do..tilt sideways and then no problem...just another one of those little idiosyncrasies (yes, I know..big word) we Stang owners have to deal with..still love my Pony...
Old Nov 22, 2006 | 09:42 PM
DoctorQ's Avatar
DoctorQ
From what I've read, Ford "corrected" the fill problem in late 05, so all 06s should not have this issue. If you have an 05, take it in and under warranty, they'll change out your fuel tank. I've got a 2006GT, and fill problem has happened to me twice in the last 3 months.. so not sure the 'fix' truly corrected the issue. But like everyone else has posted, just fill slow, or hold nozzle at a different angle to allow for air displacement.
Old Nov 22, 2006 | 09:52 PM
mlcrycc's Avatar
mlcrycc
LOL...+1....
Old Nov 22, 2006 | 09:59 PM
johnnyv8's Avatar
johnnyv8
ORIGINAL: DoctorQ
mine is a late 06..and i was the last guy who start a post on this; still have the problem but have not had the chance to go to ford.
Old Nov 22, 2006 | 11:44 PM
frzn pony's Avatar
frzn pony
They replaced the tank inmy 05. it got a lot better,but still have problems depending on the station
