whats next???
ok, heres the scoop, 07 gt with eibach pro's, 18x9 dd chrome bullits, 265/35/18's. question is whats next suspension wise? i need a panhard bar to center the axle i know for sure. its ordered. is there anything that i absolutely need to do besides that? i hear lca's is also a must? im not in the track scene so handling is not a major issue. i just know that lowering the car had to throw the dimensions off. id rather spend money on appearance and motor so please let me know if i have to do anything else. thanx guys!
You should definitely invest inadjustable LCA's to correct your angle. LCA's don't do much for handling, they are mostly to keep your power on the ground and stop that annoying wheel hop. I want to go with a similar setup as you and LCA's will be a must.
i appreciate the advise furious. so your saying that basically when i lowered it it threw some dimensions off and that the lca's will correct this? what brand should i go with? im not educated on lca's but have seen adjustable ones and i think ones that dont adjust? which would you go with? thanx alot!
