Gas Gauge Drop to zero!!!!
Old Feb 7, 2007 | 01:02 AM
RetroS197's Avatar
RetroS197
Default Gas Gauge Drop to zero!!!!
Ok, I was just doing an average accel from a light and all of a sudden the gas tank gauge dropped from about 3/4 full to E and the message said 13 miles till empty!! then I stopped and it slowly went back up to about 1/4 way!!! its still wrong!! I need help, I rely on it to tell me when to fill. I know I am not spilling gas all over the road. Anyone have any Idea?? If I takeit to Ford they might notice my off road X and tell me they wont fix it. anyone??
Old Feb 7, 2007 | 01:32 AM
Zellanor's Avatar
Zellanor
Default RE: Gas Gauge Drop to zero!!!!
more than likely your float is sticking, but don't quoate me on this. the same thing used to happen in my 87 Crown Vic.
Old Feb 7, 2007 | 02:09 AM
06windveilgt's Avatar
06windveilgt
Yea if i were you i wouldn't worry about. The first time i did a burn out my tank fell to E and miles to empty read 0. After about an hour it was normal again. IT was a 1 time thing for me and hopefully shouldl be for you too.
Old Feb 7, 2007 | 02:10 AM
RodeoFlyer's Avatar
RodeoFlyer
It happens to all of us. Don't lie - it wasn't on a "light" accelaration
You should hear it go off in every turn on a road course - very annoying.
take it to the dealer
Old Feb 7, 2007 | 02:28 AM
FLA Dreadhead's Avatar
FLA Dreadhead
ORIGINAL: RetroS197
that happen to me before too, just turn your car off and crank it back up and it should go to back to being accurate...that worked for me....
Old Feb 7, 2007 | 04:05 AM
bl1nk's Avatar
bl1nk
ORIGINAL: RodeoFlyer
I have had it happen on a very fast u-turn... I think it should go back to normal if you turn off your car and then turn it back on... I seem to remember mine doing that? (I could be wrong though)... I can only imagine what you must feel like Rodeo [8D]... isnt there a way to diable the beep at least? I would think there should be, since you can turn off just about everything else.
Old Feb 7, 2007 | 08:30 AM
howarmat's Avatar
howarmat
s197 Junkie
TSB on the issue
http://www.2005stang.com/gallery/alb...el%20gauge.pdf
Old Feb 7, 2007 | 09:23 AM
HMUSN's Avatar
HMUSN
yea .. happends to me too.. whenever i mash the throttle for some odd reason my gas guage drops rather quickly.[sm=gears.gif]
Old Feb 7, 2007 | 11:04 AM
cheftjpeck's Avatar
cheftjpeck
ORIGINAL: RetroS197
hey retro....happened to me...took it to ford, at first they just put in techron cleaner..that did not work....so took it to them a 2nd time, they replaced the fuel sender unit.....take it to your dealer and advise them of the TSB posted above....Now mine after fillup takes a little longer to go to full (Not instantly) but it gets there and measures accurately until I fill again, then it will stick for a minute or so then register correctly.
Old Feb 7, 2007 | 07:56 PM
John06GT's Avatar
John06GT
happens to me every once in a while... once I turn it off and restart it, it always go back to normal.
