Synthetic Oil
Old Mar 13, 2007 | 04:34 AM
lynwood78's Avatar
lynwood78
Default Synthetic Oil
Should I go eith Royal Purple or Mobil 1?
Old Mar 13, 2007 | 06:29 AM
fosman77's Avatar
fosman77
Default RE: Synthetic Oil
I'm happy with Castrol Syntec.
Old Mar 13, 2007 | 02:40 PM
howarmat's Avatar
howarmat
s197 Junkie
Many threads with this debate....please use the search to find pros and cons with each. I use RP.
Old Mar 13, 2007 | 03:33 PM
jrm1900's Avatar
jrm1900
Probably you wont see much of a difference among synthetics until your engine reach the end of its usefull life which under normal driving conditions and periodic maintenance should be well beyond 100k miles, and then you wont have much to compare against.
My preference is Mobil 1 I've been using it since 92 and never ever had an engine failure or smoke due to premature wear. just dont wait 10K miles to change the oil, I never go beyond 5K between oil and filter changes.
Old Mar 13, 2007 | 03:51 PM
fordfanboy's Avatar
fordfanboy
I ♥ Acer
I used to be a stout mobile 1 user for a long time but as the car progressed, I now use Torco.
Old Mar 13, 2007 | 05:00 PM
lindseyquads's Avatar
lindseyquads
ORIGINAL: lynwood78
Like JRM900 said you are not going to see a big difference between different synthetics there are lots of good brands out there, I use Royal Purple myself but you cant go wrong with Mobil 1 either. Personal preference
Old Mar 13, 2007 | 05:42 PM
Drivesthebeast's Avatar
Drivesthebeast
I use the Ford Motorcraft 100% synthetic right now....it seems to work well...better than the conventional oil or blended oil Ford puts in them in Canada...
I may or may not switch to RP or something, if I can find somewhere that friggin sells it near me!
Old Mar 13, 2007 | 06:01 PM
ezio350's Avatar
ezio350
why is it 5w-20 and not 5w-30? this is my 1st car that requires 5w-20...
Old Mar 13, 2007 | 06:12 PM
22kart22's Avatar
22kart22
since the engine was manufactured with tighter tolerances, the viscosity of the oil needs to be sightly lower (or so they say) to get into every moving part...
Old Mar 13, 2007 | 07:50 PM
owero01's Avatar
owero01
I let Ford do my oil changes. I add 4ozs of Tufoil after each oil change. I add a bottle of Zmax Fuel treatment to the gas as well.
