Your best 60ft time?
Old Mar 28, 2007 | 06:36 PM
Speedyejl's Avatar
Speedyejl
Default Your best 60ft time?
Hey just curious what these cars can pull with a good driver. Would love to see times on stock tires.
List the following:
60ft time - Tire - Tire Size - Tire PSI - Track Temp - Suspension Mods
Mine:
2.22 - Stock - 235/18 - 30psi - 35* - None
Old Mar 28, 2007 | 07:38 PM
modular81's Avatar
modular81
Default RE: Your best 60ft time?
1.97 60ft
235/50/18 stock 18inch polished bullets with bfg kdws tires
45psi in the fronts and 23 in the rears
about 50degrees
no suspension mods/ stock gears3.55
Had to abort the run though, 2nd gear i almost got sideways.
Old Mar 30, 2007 | 12:36 AM
spyder7724's Avatar
spyder7724
1.840 with stock pirellis 23 psi
1.697 with m/t e.t. streets( i've added a few things since i last ran it with the pirellis on so i think i can get into the 1.7's now.)
lots of suspension work. all for drag racing. 4.30 gears
TCI 3800 stall converter leaving at 2200rpm on pirelli and 2700 on m/t's
Old Mar 30, 2007 | 11:00 AM
Wally39's Avatar
Wally39
1.873 on my stock 17" Pirelli's. When the track opens up April 14th, I'm going to try and do better.
Old Mar 30, 2007 | 11:23 AM
ezio350's Avatar
ezio350
I see good times with 23psi. MM&FF had an article last month saying that if you deflate street tires, it will hurt traction do to less foot print. They also talked about not heating street tires with burnouts, which causes the tires to get greassy. Then again you guys had pretty good 60ft times with 23psi on stock tires... Whats your input? I was able to get a 13.8 once. Thereafter, everything is 14.0-14.2sec. How are you guys launching? Im right at 1,700RPM. Anything belog, car boggs and anything above car spins too much.
Old Mar 30, 2007 | 11:28 AM
Wally39's Avatar
Wally39
That's what I launch at is about 1800 rpm. Mine's an automatic. I spin my tires just enough to get the water off them from the water box. I've never let any pressure out of my tires either.
Old Mar 30, 2007 | 01:14 PM
ezio350's Avatar
ezio350
mine is 5spd. so I think is harder to launch. But 1,700-1,800RPM fits pretty good.
Old Mar 30, 2007 | 05:44 PM
fordfanboy's Avatar
fordfanboy
I ♥ Acer
stock motor with vortech -
Street Tires - 1.98 (3.33 gears Steeda Upper and lower CA's, Panhard bar, eibach springs only)
MT ET Streets - 1.57 (4.10 Gears, Metco Upper and Lower CA's, QA1 shocks and struts, Moser axels, welded subframe box connectors, eibach springs)
Built Motor with turbo -
MT Slicks - 1.46 (all of the above + BMR Extreme Anti roll bar, Detriot Locker, LPW Girdle)
Built Motor with custom screw blower -
Coming soon....[8D]
Old Mar 30, 2007 | 11:37 PM
Meangreen1200's Avatar
Meangreen1200
Whats the lowest tire pressure you can run on street tires?
Old Mar 31, 2007 | 12:43 AM
06VistaBlue's Avatar
06VistaBlue
I have a couple 1.78's on my stock Pirelli's.
