Will it help at the track
i actually did this today, and took it around town...
maybe it was just my imagination, but i actually could feel a difference.
i don't know how much ~20ish pounds would make though... :\
so it was probably all in my head..
20lbs?????No way Bro.If you remove the tire,jack & carpet you will pull closer to 60lbs!And yes,if you strip the trunk and deflate the tires to 23-25lbs you will turn a better 1/4 time as long as you can drive!If you dont use the rear seat then remove it and all the seat belts,brackets & hardware.this will cut about another 40lbs.Its easy to do also!
Hope you guys don't mind a 4.0 coming over to browse...
Yes, for sure remove all spare tire, jack, carpet, etc... back seats too if you can.
The general rule of thumb is 100 lbs = .1 of a second, which is pretty substantial.
Edit: also show up at the track with 1/8 tank or less of gas, can also remove front swaybar as its just a couple bolts.
ORIGINAL: Norse1974
But I've heard people say to leave it in, for better "weight distribution" and for better traction...bs? just leave it out?
Nah Bro.Take that **** out and lighten up your ride of some unwanted weight.If your worried about hooking then get some D/Rs & do a few mods to your suspension like LCAs,BMR sway bar delete(also cuts 26lbs from the nose) & look into a rear sway bar.But pulling weight from these cars should be a priority if your serious about racing.You as the owner just have to decide how serious of a diet you want the car to go on.
ORIGINAL: Arwing
Well I was just basing this off my arm scale.
ORIGINAL: Norse1974
Its not hard.The seats pop right out actually then you will need a basic socket set to remove the brackets & hardware.If it takes you longer then 30mins then you took a beer break!LOL!
ORIGINAL: Wally39
How hard is it to take out the back seat?
