Where to hook up gauge light?
Can someone tell me where the best place is toconnect the wires for the light in my boost gauge? I want it to come on when the dash light come on.
I installed the boost gauge vacuum line and pillar pod last night but ran out of time before doing the electrical part. Any help would be appreciated. Thanks! |
RE: Where to hook up gauge light?
hope this can be of benefit[/align][/align][/align]
For a better, printable copy go here: http://www.cherod.com/mustang/HowTo/...wireColors.mht [/align] MODEL YEAR(S) MUSTANG 2005 - [/align] KEY T-HARNESS IMMOBILIZER N/A N/A FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM, Requires 791 and Extra Ignition Key [/align] PART COLOR LOCATION DIAGRAM 12 VOLT CONSTANT LIGHT GREEN/PURPLE (+) IGNITION SWITCH HARNESS STARTER DARK GREEN (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 WHITE/YELLOW (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 BLACK/PINK (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE N/A PARKING LIGHTS ( - ) BLACK/LIGHT GREEN (-) @ SJB, BLUE 52 Pin Plug, Pin 31, See NOTE *1 PARKING LIGHTS ( + ) DO NOT USE! POWER LOCK WHITE/PURPLE (TYPE B) @ SJB, BLACK 26 pin Plug, Pin 3, See NOTE *1 POWER UNLOCK DARK BLUE/LIGHT GREEN (TYPE B) @ SJB, BLACK 26 Pin Plug, Pin 1, See NOTE *1 LOCK MOTOR WIRE RED/ORANGE (+) IN DRIVERS KICK PANEL DOOR TRIGGER LIGHT GREEN/YELLOW (-) @ SJB, GRAY 26 Pin Plug, Pin 25, See NOTE *1 DOMELIGHT SUPERVISION USE DOOR TRIGGER TRUNK RELEASE WHITE/PURPLE (-) @ SJB, BLACK 52 Pin Plug, Pin 13, See NOTE *1 SLIDING POWER DOOR N/A HORN DARK BLUE (-) @ SJB, BLUE 52 Pin Plug, Pin 39, See NOTE *1 TACH Any wire that is NOT RED @ any IGNITON COIL or FUEL INJECTORS WAIT TO START LIGHT N/A BRAKE LIGHT GREEN (+) @ SJB, GRAY 36 Pin Plug, Pin 16, See NOTE *1 FACTORY ALARM DISARM LIGHT BLUE/BLACK (-) @ SJB, BLACK 26 Pin Plug, Pin 16, See NOTE *1 ANTI-THEFT FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM TRANSPONDER @ IGNITION SWITCH TUMBLER [/align] NOTES NOTE *1 The SJB (Smart Junction Box) is located in the PASSENGER KICK PANEL. [/align] LINK 1 LINK TEXT 1 LINK 2 LINK TEXT 2 [/align] EXTRA INFORMATION [/align] |
I got it. Tap off the black wire with the white stripe that is connected to the dimmer switch plug for the 12 volts and ground to the chassis (i used one of the mounting studs under the dash). Took 10 minutes.
Thanks! |
Isn't that hot all the time?
The wire he used isn't hot all the time, and it will dim with the interior light reostat.
Hawgman is correct. It is not hot all the time and it dims the gauge light perfectly!
