SLP Install
Old May 7, 2007 | 07:39 PM
Ballistic1976's Avatar
Ballistic1976
Default SLP Install
Hey fellas. I just got my SLP Loudmouth Axlebacks. I was just wondering if there was anything I should look for or watch out for while installing them. Any help would be much appreciated.
Old May 7, 2007 | 07:53 PM
FuriousGeorge's Avatar
FuriousGeorge
Default RE: SLP Install
I don't know if other people had the same issue as I had installing my Stingers. The problem I had was the tiny bit of clearance directly between the muffler and one of the bolt points. Since I have only a socket wrench and a set of regular wrenches (no ratchet type), it took FOREVER to get them on and off. I think you'll have more clearance with the loudmouths so hopefully it won't be an issue.
Old May 7, 2007 | 08:00 PM
OxSMSxO's Avatar
OxSMSxO
The above poster is correct, removal can be tedious, but nothing you really need to know. Cake mod, get em centered takes more time then the install.
Old May 7, 2007 | 08:29 PM
Grabber72's Avatar
Grabber72
+1
Old May 7, 2007 | 08:31 PM
Legion455's Avatar
Legion455
This weekend I installed a set of frpp GTAs on my ride, ... and to do the job, you should have/get a 13mm box-end ratchet wrench, and you'll also need regular 13mm and 15mm sockets (deep well is even better).
Once finished, ... if the tips aren't centered in the cutouts, don't waste 2 hours trying to force them into position, ... just take your car to an exhaust shop. THisis what I did (Midas), they put the Stang up on a lift and 5 minutes later everything was right. - They did the job so quickly, they didn't even charge me, .. but I tipped the guy $20 anyway.
take care, hope this helps.
ALlen
Old May 7, 2007 | 08:56 PM
Ballistic1976
Thanks for all the posts guys, it helped a lot.
Old May 7, 2007 | 08:58 PM
FuriousGeorge
No problem, good luck with your install!
Old May 7, 2007 | 09:04 PM
VerginaStang's Avatar
VerginaStang
Installed them on Sat... the post above outlines what you need. I loosened the 4 bolts (2 on each side) after the midpipe... gave me some play when lining them up. Enjoy them, they sound great.
Old May 7, 2007 | 10:49 PM
Black Sunshine 07's Avatar
Black Sunshine 07
SLP has a very good fit. only thing tedious is removing the stock cans
Old May 11, 2007 | 10:13 PM
Gruntstanger's Avatar
Gruntstanger
I installed them myself and the only trick was centering the tip. To me it was easier to disconect the mid pipe then instal the axelbacks
