Do I need to???
Hey, just put on an off road X-pipe, and was wondering if I would gain enough to add shorty headers to it?? If anyone says you cant tell on the butt-dyno with out cats, they are crazy!! So cool, but had to put stock mufflers back on![&:]
Thanks
Thanks
I am, but your right, for $250 I got almost the same gains as $900 long tubes!! That is why I need to decide if adding shorties will make sense?? I will be getting my blower when I put the car up for the winter[:'(]
I know that long tubes are optimum and the way to go to get every hp from the exhaust system. But if you can tell a difference just by removing the cats, you are part of the way there. The shorty headers ARE less restrictive than the factory exhaust manifold, so you should be able to pick up a few more.The downside is that it will be lessof a gain as long tubes+ non-cat midpipe.
I am in the same boat. I don't want long tubes because of warranty issues. If you have problems with a CEL related to the oxygen sensor, then you are on your own.
