Anyone use these gaskets?
http://www.quadratec.com/products/52416_110.htm
Well the shop that installed my diff girdle broke one of my load bolts, so i'm going to have to pull the cover when i change the oil to replace the bolt. I'm assuming I have to replace that gasket that came with the girdle.
Anyone using redline gear oil? Their website says to use 80w140 for limited slip diffs.
I saw these gaskets and was so impressed I bought one. I will install it whenever I change the oil or IF I decide to go with 4.10's. Yes, I am using Redline in my diff and tranny. Good stuff.
You mean you just bought one? I was unimpressed with the gasket that came with my diff girdle. I'm suprised it's not leaking.
What weight of gear oil did you use? I read crazyAl's post that mentioned the shock proof, but i'm not sure that's the right stuff.
ORIGINAL: Goldenpony
