Delete plates
Old Aug 22, 2007 | 06:32 PM
Savanah07's Avatar
Savanah07
Default Delete plates
Ok, so i was thinking about getting delete plates from brenspeed since they will retune for free. which are the best plates to go with, the cast or the billets? they emailed me back and said that the cast they have tested but not the billets. OR should i go with another brand of delete plates altogether? and can i install the delete plates myself. i did my cai by myself? You guys really help with decisions.
Old Aug 22, 2007 | 06:50 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: Delete plates
the billet are completely pointless unless you like spending 300 on something that you can get for 140 and there are no other delete plates other than the steeda. CAI is easy but the delete plates require alot more....look through Tacobills post on them and you decide if you want to do them yourself.
Old Aug 23, 2007 | 09:20 AM
acascianelli's Avatar
acascianelli
ORIGINAL: howarmat
+1, don't bother with the billet plates.
I plan on doing the install myself, from the looks of it two important parts are making sure NOTHING gets in the heads, and torqueing down the intake properly.
Old Aug 23, 2007 | 10:34 AM
hammeron's Avatar
hammeron
i would say you'll be fine, doing your own.
the intake manifold bolts are only lightly
torqued down, so they loosen up very easily (this
was a worry of mine).
if taco has a write up on this, then your home free
Old Aug 23, 2007 | 11:36 AM
jetstang's Avatar
jetstang
Do you really feel more power from these deleate plates?
check my sig. Will they be a good addition to what I already have?
More RWHP or not?
Thanks, Michael
Old Aug 23, 2007 | 12:02 PM
howarmat's Avatar
howarmat
s197 Junkie
Yes you should get the plates....you will get more out of plates than most since you have a full exhaust already
Old Aug 23, 2007 | 02:29 PM
Hufenstang's Avatar
Hufenstang
when pushing really high rwhp ( 550rwhp +) is it best to get delete plates?
Old Aug 23, 2007 | 02:38 PM
06Saleen3V's Avatar
06Saleen3V
I too am debating getting DPs...I am not too familiar with what they work best with...can someone with more experience in this category chime in and let me know if delete plates are a good decision for me? Look at my sig for my mods...thanks in advance
Old Aug 23, 2007 | 03:06 PM
acascianelli
ORIGINAL: 06Saleen3V
Are you running stock mufflers? If so, how loud is that O/R H-pipe with the stock mufflers?
Old Aug 23, 2007 | 03:10 PM
06Saleen3V's Avatar
06Saleen3V
ORIGINAL: acascianelli
No stock mufflers here. Saleen has a Magnaflow system that is kind of weird, sounds good, but weird. Im gonna try my best to explain it. They have normal mufflers but the back of the mufflers has two openings, one dumps directly out of the muffler and the other is a pipe that goes out the centered-out exhaust. It sounds absolutely amazing with the o/r H-pipe. Any word on the Delete Plates though...im really curious about em!
