Engine knock..
Old Oct 24, 2007 | 08:32 PM
1clean07's Avatar
1clean07
Default Engine knock..
So here's the deal....Driving home tonight, in 2nd and stomp on it up a hill...the engine knocks. Now I'm down to a 1/4 of a tank of gas and there was no knocking during the first 3/4....Bad gas ya think? Never had a car that knocked unless it was really old...I have no mods absent some mufflers so it isn't a bad tune.
Old Oct 24, 2007 | 09:22 PM
hammeron's Avatar
hammeron
Default RE: Engine knock..
i would say fill up the tank and take
another run up that hill....
if it still pings, then you might try higher
octane or a different gas supplier
Old Oct 24, 2007 | 10:07 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Maybe the fuel pump TSB as well. Either the fuel pump is not getting the gas in the tank or the pump isn't working properly and getting the gas to the motor. JMO but.....hope it helps
Old Oct 24, 2007 | 10:38 PM
owero01's Avatar
owero01
Try adding Lucas fuel injector cleaner lubricant or Marvel Mystery Oil to a full tank of gas. You may want to try a different gas station as well just in case they have water in the tank.
Old Oct 25, 2007 | 09:25 AM
ski's Avatar
ski
+1 on trying different brands of gas. But before using higher octane gas, suggest trying a can of Seafoam. It got rid of my pinging problem.
Old Oct 25, 2007 | 03:34 PM
Daniel60's Avatar
Daniel60
It saids in the manual it is normal to hear pinging sometimes it's when you drive it constantly when it should be a concern. Look in your manual I'm to lazy to look it up.
Old Oct 27, 2007 | 05:48 PM
SteveGTR's Avatar
SteveGTR
Kenne Bell literature indicates that you should treat 1/4 of a tank as empty:
http://www.kennebell.net/techinfo/fo...gtTechTips.pdf
Look on page 10, "FUEL LEVEL".
Old Oct 28, 2007 | 01:20 PM
JGT's Avatar
JGT
ORIGINAL: ski
Same here. I had pinging everytime I floored it. After I determined it wasn'ta tune issue, I tried the Seafoam and I haven't had pinging since.
Old Feb 18, 2009 | 12:21 PM
Sirsilent's Avatar
Sirsilent
is that the stuff?
http://www.seafoamsales.com/motorTuneUp.htm
I might try it as well
Old Feb 20, 2009 | 02:17 PM
Lifter583's Avatar
Lifter583
Techron is the ONLY recommended gas additive.
