Engine ticking.....
Old Oct 28, 2007 | 04:10 PM
07VBmustangGT's Avatar
07VBmustangGT
Default Engine ticking.....
Ok, the past couple of days i've been noticing a ticking coming from the engine, so today I open up the hood and listen around and it sounds like its coming from either the injectors, intake manifold, or maybe underneath the manifold from the lifters and can't tell which one. I have about 8000 miles on itanda C&L intake and a brenspeed 87 tune right now because when I'm at 89 or 91 tune the ticking gets worse and more pernounced at WOT or even at semi-hard acceleration. I put fuel injector cleaner in and ran about half a tank but the ticking is still there. SoI was just wondering if anyone else had this tick coming from that area and should I take it in the ford and have it checked out so it doesn't screw anything up. I wouldn't be so concerned with this but it sounds like crap when underacceleration.
Old Oct 28, 2007 | 04:21 PM
moosestang's Avatar
moosestang
Default RE: Engine ticking.....
If you can hear it under acceleration then it's pinging and you should either get a new tune or try a higher octane gas. The injectors on these cars do tick, but it's not audible from inside the car.
Try the 89 tune with 91 gas.
Old Oct 28, 2007 | 04:24 PM
07VBmustangGT
Yeah I've tried that. I've tried different gas stations and running 91 gas with a 87 tune still does it.
Old Oct 28, 2007 | 04:57 PM
hammeron's Avatar
hammeron
+1 to what moose said...
i would add.....it may be time to return your
car to completely stock, take it in and let
the dealership diagnose and fix this....
Old Oct 28, 2007 | 04:59 PM
07VBmustangGT
Well, I emailed brenspeed to get a new tune, but I returned the car to stock and for some reason it still doing it and sounds even worse at idle and under acceleration. I'm not sure if the tune was the problem now.
Old Oct 28, 2007 | 05:02 PM
07VBmustangGT
Ok thanks for the replies I'll probably just go back to stock and take it in to the dealership.
Old Oct 28, 2007 | 05:18 PM
hammeron's Avatar
hammeron
more info....
[IMG]local://upfiles/37808/E1943871F6034A32B3014A96B675BFA9.jpg[/IMG]
[IMG]local://upfiles/37808/30359C43C54743B09DEC6D2EE8DDB02F.jpg[/IMG]
Old Oct 28, 2007 | 09:07 PM
smythge's Avatar
smythge
Bring it in and get it checked out.
ORIGINAL: 07VBmustangGT
Ok, the past couple of days i've been noticing a ticking coming from the engine, so today I open up the hood and listen around and it sounds like its coming from either the injectors, intake manifold, or maybe underneath the manifold from the lifters and can't tell which one. I have about 8000 miles on it and a C&L intake and a brenspeed 87 tune right now because when I'm at 89 or 91 tune the ticking gets worse and more pernounced at WOT or even at semi-hard acceleration. I put fuel injector cleaner in and ran about half a tank but the ticking is still there. So I was just wondering if anyone else had this tick coming from that area and should I take it in the ford and have it checked out so it doesn't screw anything up. I wouldn't be so concerned with this but it sounds like crap when under acceleration.
Old Oct 28, 2007 | 09:11 PM
sactown's Avatar
sactown
+2 on what moose said, that's not a tick that's a ping, which could be fould be a boom.
Old Oct 28, 2007 | 10:08 PM
Saleen05797's Avatar
Saleen05797
Yah I hear ticking too, but its my injectors, I can only hear it with the hood open and me right there
