Car shuts off
Old Nov 3, 2007 | 01:49 PM
Saleen05797's Avatar
Saleen05797
Default Car shuts off
Hey guys,
Got the problem fixed with the car wanting to studder when cold, it was the o2 sensors. But now I have another problem to fix (it did not just start...) Every since the blower install, my car wants to shut off if I am in 5th, 4th, and sometimes 3rd and I press the clutch or put it in nuetral. If it does not shut off, the rpms will bounce and eventually shut off. My timing drops to about 8* at idle when this happens. If my car is sitting still, it sits fine (but an occassional rpm bounce). What could cause this? Vaccuum leak?
Old Nov 3, 2007 | 01:57 PM
hammeron's Avatar
hammeron
Default RE: Car shuts off
need details about your configuration
Old Nov 3, 2007 | 01:59 PM
Saleen05797
Stock engine with a KB S/C on it, KB boost-a-pump, KB intercooler. Brisk spark plugs, bassani o/r x-pipe, flowmaster mufflers, 4.10 gears, and that's basically it
Old Nov 3, 2007 | 02:05 PM
hammeron's Avatar
hammeron
so no boost gauge and no fuel pressure gauge, right?
Old Nov 3, 2007 | 02:08 PM
Saleen05797
I have a fuel pressure gauge in the engine compartment. The interior ones have not been installed yet (working on getting everything running perfect first). It tops out at 10 psi boost (this was from the dyno)
Old Nov 3, 2007 | 03:55 PM
howarmat's Avatar
howarmat
s197 Junkie
who did the install?
Old Nov 3, 2007 | 03:58 PM
hammeron's Avatar
hammeron
ok, i feel like a broken record....
what about the throttle body, have you
ever cleaned it....perhaps that is all it is.
there have been some recent threads about
poor idling and such and cleaning the TB
sometimes makes a world of difference
Old Nov 3, 2007 | 05:53 PM
sactown's Avatar
sactown
Sounds like a bad tune maybe.? My car ran great with the first tune until the outside temp dropped from 105 to about 85-90 then the car ran extremely rich, had a little trouble starting, would bog down at light and almost stall, even at WOT the car sounded like it was bogging down. You may want to put the car on the dyno, check the A/F you probably have some spikes and dips in the curve.
Old Nov 4, 2007 | 11:50 AM
Saleen05797
It's been on the dyno a good amount of times. The A/F seems to be fine all throughout. I will try cleaning the TB.
Mike Ward Racing did the install initially, but we had problems with him. Took too much time, had too many problems, and charged me for things I didn't need/didn't want and for parts that he didn't even put on. I have it at a new guy now, Dyno Tune Motorsports, and we are trying to fix all the problems that we initially had.
BTW, last night I did get error code P0191. Haven't checked if it's still on today.
KEM Motorworks
Aug 14, 2015 10:13 PM
drumhedd2005
Aug 13, 2015 09:59 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
