NEW: Speed of Sound Triple Gauge Center Dash Pod!
Old Nov 21, 2007 | 08:31 PM
Boostaddict's Avatar
Boostaddict
Former Sponsor
Default NEW: Speed of Sound Triple Gauge Center Dash Pod!
Just giving you guys a heads up about another new and innovative product that our good friend Alan@Speed of Sound put together. It's a Triple Gauge center dash pod which is made to house 3 2-1/16" gauges.
NOW SHIPPING!! $139.99
CLICK HERE FOR NON-DRILL VERSION
CLICK HERE FOR DRILL VERSION
2005-up Ford Mustang Center Dash Gauge Pods
SOS-equipped S197 Mustangs prowl streets, scorch strips and dodge cones all over the world. Owners of our products enjoy a show-quality fit and finish, while maintaining unmatched performance and functionality. Simply put, all show AND all go!
The new Speed of Sound center dash gauge pods achieve their excellent sight lines and precise fit from a strict manufacturing process. Injection molding, thermoforming, and CNC machining of ABS plastic is utilized to produce every part. 3D solid modeling and digitizing ensure accuracy unmatched by any market alternative. Custom dye blends the part with your OEM dash in effortless fashion.
Two versions are available:
Concept 1, full base assembly for a clean look with hidden wires, NO DRILLING REQUIRED for installation!
Concept 2, low profile base assembly, DRILLING REQUIRED for installation!
Designed for center dash top section of all 2005+ Ford Mustangs (coupe or convertible)
Holds three 2 1/16" gauges (NOT included!)
Gauge pods angled for a superior viewing angle
Extremely durable injection molded ABS gauge pods (US Patent# D529,422) can endure the hottest parking lots in the world without breaking a sweat.
Thick (.090") thermoformed ABS base assembly, featuring CNC milled edge for precise fit on the dash.
CNC machined ABS mounting points for easy installation, with included 3M adhesive tape.
Color matched, NO PAINTING REQUIRED!
Grain/Texture closely matches the OEM finishes, right out of the box. No other gauge holders on the market exhibit the attention to detail of an SOS product.
Concept 1
: Absolutely NO DRILLING required for installation! Wiring runs under the base panel and into the defrost vent, leaving no trace. Remove and return to stock if necessary! Speed of Sound recommends professional installation for the wiring portion of this installation.
Concept 2: DRILLING IS REQUIRED FOR INSTALLATION! Three holes (two 3/8” mounting, one 7/8” wiring) must be drilled into the OEM dash board. We have included an adhesive vinyl template to assist you in the proper placement. By purchasing this product, you acknowledge this modification is not reversible and assume all responsibility for its installation and thereafter. The dash board is an expensive part to replace. Please consider professional installation unless you are completely confident in your ability to perform the job.
Fits most all popular brands with precision (Autometer, Speedhut, DEFI, Ford Racing, Stewart Warner, VDO, Cyberdyne, Dakota Digital, etc.)
DOES NOT fit Glowshift, SPW, Megan Racing, or Prosport gauges (depth issue)
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
Nick Oliver
Oct 17, 2018 04:22 AM
musnicki
Sep 23, 2015 07:11 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
