390 s/c ?
ORIGINAL: wadman
I would say your numbers are pretty accurate depending on what type of dyno you ran it on. Some may disagree but Ive always gotten lower numbers on dynojets, but they seem to be more "real". The best test is the drag strip.
md = 90% of a DJ
ORIGINAL: CataclysmGT
More timing advance. What type of dyno is this on? I would expect 470rwhp on a dynojet, 410+ on a mustang dyno.
You will want to raise the timing up to a point where your knock sensors start detecting a knock and then back the timing down 2 degrees.
You can do the datalog while doing the pull.
Just take it easy.
Are you running the HT0 plugs gapped at .32? You are about 90HP short of where the 2200 should be. I would call Brenspeed and ask them what they think.
Also what is your altitude? You will lose 5% power for every 1000 feet over sea level. So if you were at 5000 feet then you HP might make sense.
Help a noobie out, I am looking into a 2200 Paxton kit which advertises "up to 170hp increase", assuming that is at the crank, 300HP is stock, (I have a '07 GT, auto), that would be 470 HP at the crank, 80% or so would be 376 HP at the wheels right? So prgt's #s would be about right, actually if on a Mustang dyno, pretty good! Am I missing something?
ORIGINAL: p.r gt
i"m runing 10 psi and it "s on a dyno jet and it up to 6300rpm, she haves l/t header ,x pipe andd mac a/b ,delet plates ,39 lb injectors , 0 degree plugs , bap this is a brenspeed kit
