GT Auto Trans Question
Old Jan 14, 2008 | 03:22 PM
drbobvs's Avatar
drbobvs
Default RE: GT Auto Trans Question
The "special tool" is nothing more than a threaded hose fitting. Ford charges you >$20, a hardware store approx $2. To fill you screw in the fitting attach a hose to it, pump the fluid in, remove the hose. If no fluid comes back out, fill some more. Keep adding fluid until you get a fluid return when you remove the hose (just like filling a differential). When you get fluid return wait 'til it stops dripping, reinstall the plug and it you're done.
Old Jan 14, 2008 | 03:56 PM
GidyupGo's Avatar
GidyupGo
Why would you need the fitting? Just shove the filler pump hose into the hole where the fitting is supposed to go.
Old Jan 14, 2008 | 04:03 PM
dirtydeedsinc's Avatar
dirtydeedsinc
If you're not going to install a dipstick and want to fill the tranny like above, get a clear hose to fill it with from Lowe's or Home Depot. Then you can at least see the fluid when it gets full.
Old Jan 14, 2008 | 04:09 PM
godfather_go3's Avatar
godfather_go3
I remember the old days when one just droped the pan,changed the filter, install a new gasket and fill thru the filler tube, ahh , nothing like progress and improvement . I have the 100,000 mile drivetrain coverage, I will check my manual to see if Ford says the fluid "must" be changed after X amount of miles to protect the drivetrain coverage I paid for, if not I think I will skip the fluid change and if I get a problem let them pay the bill, I have a $100.00 deductable.....
mtgldr
Feb 3, 2024 09:00 PM
97SN95GT
Sep 13, 2015 09:45 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 3, 2015 08:43 PM
iculookin
Sep 2, 2015 12:34 PM
