overdrivepully
Old Feb 20, 2008 | 03:49 PM
p.r gt's Avatar
p.r gt
Default overdrivepully
what do you guys think about this
10% Overdrive Crank Balancer Innovators West
Increase boost with this aluminum overdrive crank pulley. If you are looking to pick up addition horsepower on your supercharged Mustang this is a simple solution
Old Feb 20, 2008 | 03:59 PM
Fleron230's Avatar
Fleron230
Default RE: overdrivepully
Well, it would give like 2.5-3 PSI IIRC.
Old Feb 20, 2008 | 06:03 PM
acascianelli's Avatar
acascianelli
Why not just buy a smaller supercharger pulley? It would be easier to install and probably cost less.
Old Feb 21, 2008 | 12:02 AM
hypersurf1's Avatar
hypersurf1
With a smaller supercharger pulley you stand a good chance of belt slippage due to less contact area with the belt. This overdrive pulley increases boost without going with a smaller pulley and reducing your chance for belt slippage. Thats why this is a better solution.
This is the way i am going to increase my boost 2-3 psi.
Old Feb 21, 2008 | 01:21 AM
Hufenstang's Avatar
Hufenstang
i use it and havent had any problems with it
Old Feb 21, 2008 | 04:02 PM
p.r gt's Avatar
p.r gt
how much psi did you get with the pully and performance wise, where was you at before and afther
Old Feb 21, 2008 | 04:13 PM
modaddict's Avatar
modaddict
ORIGINAL: Hufenstang
What psi are you pushing it with? Everyone I know using an overdrive pulley over 12 psi has MORE belt issues from it. Personally, I don't like any OD pulley.
Old Feb 21, 2008 | 04:14 PM
modaddict's Avatar
modaddict
ORIGINAL: Fleron230
I highly doubt that as that's more around the numbers with an 18%...
