Revised - I got it... adjusting speedometer with XCAL2
Old Feb 23, 2008 | 04:31 PM
Nuke's Avatar
Nuke
Default Revised - I got it... adjusting speedometer with XCAL2
I just replaced my stock 235/50/18's tires and fanblades with 275/40/18's and SVT 2007 Cobras and thought adjusting the speedometer would be a breeze. Reading thru the manual, itindicates that I need to download the Extreme Tune software. Before I do that, I wanted to check on what to do before I start. I've yet to connect my XCAL2 to my PC and just wanted some feedback.
Thanks, guys. I'll post some pics later.
EDIT: See post #6 below.
[sm=closed.gif]
Old Feb 23, 2008 | 05:35 PM
CataclysmGT's Avatar
CataclysmGT
Default RE: Help adjusting speedometer with XCAL2
Umm, RELOAD the tune. During the initial selection, it asks if you want to change and optional parameters. Select the tire size option, and then select the "revolutions per mile" that your tire size would be (manufacturers give you this). Continue to load the tune, and you are set.
Old Feb 23, 2008 | 05:38 PM
Black_06GTStang's Avatar
Black_06GTStang
I'm pretty sure all you need to do is hook up the XCAL to your car and change the revolutions per mile under optional parameters. Your revs per mile are 756 with the new rims and tires. Diametersize is 26.7in. Choose 755 in the XCAL under revs per mile and your good to go. Hope that helps.
Old Feb 23, 2008 | 06:14 PM
Nuke's Avatar
Nuke
From the XCAL2 manual, it says I need to download the Extreme Tune software and the .xtr file from Brenspeed. I had previously tried the tuner AND reloaded the tune but didn't see the "change optional parameters" choice however, I DO recall seeing that once before.I DID install the Extreme Tune software but will have to wait until Monday for Brenspeed to get the .xtr file... Unless someone here insists I should just be able to plug and play and make the change.
Old Feb 23, 2008 | 07:13 PM
Black_06GTStang
I guess it's possible that the Brenspeed tunes are locked out so that you can't tamper with them. I'm sure they'll help you out. Good luck!
Old Feb 24, 2008 | 07:16 AM
Nuke's Avatar
Nuke
OK, so I feel pretty stupid right now and relieved at the same time. I was pretty sure I didn't need to do anything "special" but I really must have been brain dead last night. I went to the brenspeed website this morning. Under "SCT Xcalibrator 2 Training Videos" I watched the video "Click to View Operating User Adjustability" . I guess I just didn't scroll far enough thru the menus when I tried last night. I reloaded my tune and made the adjustment for revs per mile. Now my speedo should be good-to-go. See what a good nights sleep can do? If only the crappy weather would let up...
Old Feb 24, 2008 | 10:37 AM
Black_06GTStang
Glad to hear you got it sorted out!
Old Feb 24, 2008 | 01:12 PM
explict's Avatar
explict
Good thing, Now whenever I am stuck on something like this I know where to look!
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
