pulling engine from the S197
I am getting ready too pull the engine from the wrecked 2007 and want to know where i am suppose to hook to the engine to properly hoist it. i saw these threaded holes on the heads but didnt know if these are the point to do it. Are these points strong enough to support the weight of the heads, block and tranny when I pull the whole thing?
[IMG]local://upfiles/59163/CB6F208417DC446FA8F67C5D1F647001.jpg[/IMG]
hopefully someone with experience can chime
in and help ya gypsy...
it looks like ford has you lift from the top
of the engine, tho i'm not sure exactly
which holes....
[IMG]local://upfiles/37808/C99A96FA10DE48C1A247DF255E638DB8.jpg[/IMG]
[IMG]local://upfiles/37808/6B54AF6EBEB74855B2118E99B5CA546F.jpg[/IMG]
which holes....
gypsy, no.... no mention of bolt sizes
ORIGINAL: hotairgypsy
you rock!!! i would have never thought of looking there...does your manual say what size bolts get screwed in?
looks like it is OK to lift from the heads...wow that is a whole lotta weight for the heads to hold up
ORIGINAL: PLstang
Here is a picture of where they hooked on to my motor at. However, they used a special bar so not sure if this is any help!
