Vortech Question
Old Mar 23, 2008 | 10:55 PM
PizZle's Avatar
PizZle
Default Vortech Question
I've been looking into purchasing a Vortech Supercharger for my 05' Gt (Auto) and im on somewhat of a limited budget...i've found a polished Vortech kit without the aftercooler for 3800.00 and a polished kit with the aftercooler for 4800.00 My dad owns an Automotive Performance shop so i won't have to pay anything in labor/time etc.
My question is...is the extra grand for the aftercooler really worth it??? I've done some research and it seems like the people without the aftercooler are getting around the same amount of rwhp compared to the guys with the aftercooler.
Thanks
PiZzLe
Old Mar 23, 2008 | 11:00 PM
danGT06's Avatar
danGT06
Default RE: Vortech Question
If you want more power down the line I would get the aftercooler. I'm pretty sure the most boost you can safely run without the aftercooler is 8psi. If you can afford it right now just get the aftercooler. If not, it would be really easy to add one later you could even get the paxton air/air cooler which is what people seem to prefer over the air/water aftercooler from vortech.
Old Mar 24, 2008 | 05:14 AM
Stkjock's Avatar
Stkjock
Retired Mod
the aftercooler allows you to run about 2-3 lbs of boost more than the non-ic set up. it also provides lower IATs which is safer for you motor. Especially if you in a hot climate. Will also give you better power sustainablity in hot weather.
when i did mine i calculated the added potental power per $ and iirc those added HP were "cheaper" than the first 120 or so that the non ic kit adds on its own.
Old Mar 25, 2008 | 12:26 AM
cenotaph's Avatar
cenotaph
I've asked a similar question before regarding the aftercooler setup. I was told that you cannot run more than 350-360hp with the nonintercooled setup. I don't know why.
I'm curious, I live in Phoenix where it gets hot as hell in the summer... is the nonintercooled version a **** poor idea or what?
Thanks
Old Mar 25, 2008 | 01:40 AM
modaddict's Avatar
modaddict
Without question you should get an intercooled or aftercooled kit with ANY FI...
Old Mar 25, 2008 | 01:53 AM
hypersurf1's Avatar
hypersurf1
I would say it depends on your HP goals. If you can live with 425HP or less then non IC should be ok. If you plan on running up towards 500HP or more then get the IC. The IC will only allow you to run more boost and more timing without running race gas. If you run race gas or meth injection you can run more boost and or timingwithout the IC. The IC is a good way to avoid having to run race gas or meth injection while pushing more boost. You should be able to get a better price then that on those blowers. I would look for 3600 on the non IC and 4400 for the intercooled. I paid 4200 for my Paxton 2200 HO Kit. Good luck.
Old Mar 25, 2008 | 06:29 AM
05 Mustang's Avatar
05 Mustang
spend the additional money up front and do it right from the start....you'll be glad that you did
[IMG]local://upfiles/50057/04CBDC8B654647FEA5084A567F6DCDC1.jpg[/IMG]
Old Mar 25, 2008 | 10:28 AM
Stkjock's Avatar
Stkjock
Retired Mod
ORIGINAL: 05 Mustang
well said!!
Old Mar 25, 2008 | 11:41 AM
PizZle's Avatar
PizZle
thanks guys! i appreciate all the words of wisdom...i think that i am going to just increase my budget and purchase the right thing..instead halfway doin it. I found a Paxton 2200 HO Kit with an air-to-air intercooler for 4,095.00 seems like a pretty good deal to me.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
