Octane Booster
I'm going to the drag strip for the first time (with this car) this Saturday and I want to use the 93 octane tune from steeda that is loaded on my diablosport tuner. I know I could do better, but the tuner came with the car, I'm not buying another tuner when I already have one, but I digress.
Problem is the best gas I can buy is 91 octane, unless I go with ethanol blended gas which I can get in 94 octane. I've been advised by a local Saleen owner and all round Mustang expert to, and I quote, "DO NOT USE ETHANOL BLENDED GAS!!!!!!!!!".
I was thinking of picking up a bottle of octane booster for this occasion. NOS makes one that boosts octane 3 points for about $10 bucks. It's the "street" formula.
Anyone used this product?
The former owner of my car also suggested to manually increase fuel and timing using the tuner. Is this a good idea for someone not all that experienced? Any suggestions for settings?
Thanks
Thanks
Do not run octane booster, you will ruin your spark plugs. Buy a Bamachips race tune, they're only $50 and they are much MUCH better than the canned Diablosport tune. I upgraded from a canned Diablosport tune to a Bamachips race tune and the difference was very noticeable.
But, once again...
DO NOT RUN OCTANE BOOSTER.
But, once again...
ORIGINAL: acascianelli
But, once again...
But, once again...
ORIGINAL: Vapour Trails
Thanks
Thanks
Second, The octane boosters that you are refering to raises your octane by up to three points. A little missleading. What they mean by points is (0.1) So one bottle would raise 10 gallons of 91 octane to 91.3 octane. Not very impressive. you would need about a dozen bottles to bring it up to 93!
The best way to increase your octane would be add Toluene to the Gasoline. Pure Toluene has a rating of around 121 so if you add 1 gallon of Toluene to 9 gallons of 91 octane you will end up with about 10 gallons of a 94 octane brew! I use Toluene all the time in many vehicles including a boosted 100k mile S2000 and my boosted 06 stang with no trouble. Be sure it is toluene and nothing else like paint thinner or distiled alky. You can get it from most hardware stores. i get mine from ACE hardware for about $12 a gallon.
Always use common sense when playing with fuels and do the math. Dont just pour stuff in the tank without meassuring or knowing what it is?
Yes when I was driving in the US I saw that most gas had 10% ethanol and I used it without problems. In Canada most fuel is straight gasoline.
About the octane booster, it actually raised 30 points or 3 total octane units. I should have been more clear. I'll go look for some Toluene. thanks
Trust me. It is only 0.3 Do some research, many labs have tested this stuff and it does not raise the octane much. The only real benifit to this stuff is that it is a coktail of cleaners and lubricators that may help clean the fuel system but have also shown to cause harm to plugs and cats over time.
As a side note.... The chemical they use in octane booster to raise the octane level is Toluene! But they usully use less than 4% per volume in their concoction. The highest I have heard of was Berryman's. It had 8% I think. Still not much though!
