problem with Whipple install
Old Jun 21, 2008 | 12:58 PM
teedub's Avatar
teedub
Default problem with Whipple install
I finished installing my Whipple HO and everything went fine until I connected to the negative battery post. My I/C water pump started immediatelyeven before turning over the engine. Now it seems to be working in reverse. It runs, even with the ignition off, when the car is cool and turns off when the car gets up to temperature.
I hooked it up according to the manual where Ispliced intothe passenger side resistor.
Anyone with any help/ideas would be appreciated.
Old Jun 21, 2008 | 01:10 PM
hammeron's Avatar
hammeron
Default RE: problem with Whipple install
the I.C. water pump should turn on
when the key is turned to on or start.
it will stay running until the key is turned
to off.
i would just double check the wiring... this has
happened to other installers as well and it was
just a wiring issue.
Old Jun 21, 2008 | 01:23 PM
teedub's Avatar
teedub
I just double checked the wiring. I have the lead for the pump (grey wire ) installed on the side of the connector and not the resistor. Just like the manual shows.
I not saying that I did not wire it wrong, but as far as I can tell it is just like they want it.
Old Jun 21, 2008 | 03:20 PM
stang910's Avatar
stang910
Did you install the wire with the fuse to the fuse box. It sounds like you have the negative and positive wires reversed.
Old Jun 21, 2008 | 06:17 PM
teedub's Avatar
teedub
ding ding ding!!!!! we have a winner. By no means am I passing the buck as I did the install with some help....but I am not the one who hooked that up. Black to the fuse box and red to the ground.
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 21, 2008 | 07:35 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
glad they solved that problem for ya!
Old Jun 21, 2008 | 07:40 PM
moosestang's Avatar
moosestang
ORIGINAL: stang910
Bingo! Someone just recently did the same thing.
Old Jun 23, 2008 | 08:43 AM
RF2.1's Avatar
RF2.1
Yup, I did the same damn thing when I installed my Whipple. Or I should say, my friend did itThe wires were so covered up with, well, coverings, that he didn't immediately notice that he had the positive and negative reversed. Makes you feel like a real dummy when you figure it out, eh?
David
Old Jun 23, 2008 | 07:13 PM
explict's Avatar
explict
Good to see it works now though haha
I was so worried about things going wrong after my install...so far I have about 25km's! and no problems!
Old Jun 24, 2008 | 07:58 AM
AmericanSpeed's Avatar
AmericanSpeed
Countdown to my Whipple install- 72 hours
djbigskrilla
Sep 20, 2022 01:04 AM
5.0pntydrpr
Aug 27, 2015 10:26 PM
FD725
Aug 23, 2015 06:43 AM
jjwinel78
Aug 17, 2015 03:34 PM
Pain.
Aug 7, 2015 10:48 PM
