engine sputtering at track
has anyone else had the problem of the enging sputtering during hard left turns? It seems to be fuel pickup related, but this is happening with just over a 1/2 tank. Do we not have baffles in our fuel tanks, or is there something else going on?
thx
thx
I was curious about fuel starvation on cornering too, though I haven't had it happen in the GT I've seen it on other cars.. I posted and got no answers either.
You running any mods that may be placing more demands on the fuel system? FI, larger injectors, etc?
i've got no mods other than a Brenspeed 93 oct tune. I've seen a diagram of the fuel tank and it seems to be a saddle tank type with only 1 line leading to the engine. I'm wondering if there's a pump to push fuel to the other side of the tank.
There is a black plastic tube that connects to the 2 sender units. The tube connects to the white wierd looking splitter connected to the fuel pumps. There is a rubber duckbill on that same white piece that when the pumps prime they start a suction from the other sender behind the passanger seat. The fuel flows from the passenger side and dumped into the driver side.
"Here is my work in progress. I spliced ford twin gt pumps into the stock hat, replaced all the wiring and deleted the pprv valve. Replaced the cheap plastic tube with gates submersible. Any other questions?
ORIGINAL: blksunshine
wow, that's some setup. It sounds like my passenger side pump is weak. I wonder if the Ford GT pumps would be to much for just a N/A unmodded motor. Thanks for the info though.
PASSANGER SIDE
DRIVER SIDE
I dont think this is a common problem, Ive seen very few posts on this issue. What year is the car? As a point of reference - mine is an 07 and I have done lots of lateral, high G turns (AutoX and Track) without any 'sputtering' issues. Good luck finding the fix.
Sevenleaf: thanks for clarifying. I'm definately having issues with fuel flowing from the passenger to drivers side.
Argonaut: I have an 07 as well, but my first instructor has an 06 GT and said it happened to him at half a tank. I'm curious, how low on fuel have you gone at the track?
