clutch problem
Old Jul 18, 2008 | 11:09 AM
shoeys08dkcandygt's Avatar
shoeys08dkcandygt
Default clutch problem
hey guys i was wondering is any of ya'll having problems with your clutches going out around 25k miles. i can hear the throw out bearing spinning until i push in the clutch and put it in a gear. not sure if something is up with the trans or the clutch. any advise would be greatly appreciated.
Old Jul 18, 2008 | 10:10 PM
Yonco's Avatar
Yonco
Default RE: clutch problem
I Just had my Clutch replaced at 34k Miles. My hydrauclic throwout ended up going and that caused me to loose a lot of my clutch, which ended up killing the clutch early. My original throwout bearing was quiet and i never noticed it. The new one, is noisy when off of the clutch, but i dont see it as a problem. -Jon
Old Jul 19, 2008 | 02:00 AM
ZeroIngold's Avatar
ZeroIngold
When you say loose a lot of your clutch what do you mean? My clutch no longer feels as heavy as it did before and seems to have a small engaging area.
Old Aug 1, 2008 | 12:36 PM
nu2ford's Avatar
nu2ford
I have also had a "Slave unit" (throwout bearing) fail at 75K. The seal failed and spewed brake fluid over my clutch &pressure plate. I had to replace all three components and have my flywheel resurfaced. All of this happened within 8 days (500miles)fromwhen I first heard the whirringnoise of a "failed" throwout bearing. Once the noise starts I recommend replacing it. The dealership wanted $1200 to repair it and my extended warranty did not cover the repair. It cost me $900 at a local transmission shop to have it repaired.
To do the repair yourself is not that bad from what I was told after the fact. Of coarse that's saying a clutch replacement is easy in general. The slave clutch self bleeds after installation. After it was first repaired the pedal was a bit spongey. however,after a week or so it became normal again.
The seal is what goes bad. I suspect from heat. Going to and fromwork I run the engine over an hour each weekday. Howeverthe sealreally warped up, upon inspection after the repair.
Old Aug 1, 2008 | 08:04 PM
wilkinda's Avatar
wilkinda
2010 Section Moderator
replaced my throw-out bearing around 38K miles. New one is noisy compared to original and i paid $260 out of pocket to havebetter quality parts installed.....
And the gear toll-over noise......please don't get me started on that [:@]
Old Aug 2, 2008 | 09:25 AM
nu2ford's Avatar
nu2ford
Better qualityparts:
I was looking for a "better quality part" when I had my throwout bearing replaced. As of last year, I couldn't find such a thing. You can buy better everything but the throwout bearing. I had mine redone with LuK parts. But again, the throwout was still from Ford.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
