Need Help error codes!
Old Aug 15, 2008 | 10:17 PM
kolb02's Avatar
kolb02
Default Need Help error codes!
Hey guys just got done installing MMR motor and now I keep getting P0340 and p0344. It's an 07 so I think my alternater is good, I already changed the cam position sensor and same thing. What could be causing this I need help!
Old Aug 15, 2008 | 11:10 PM
hammeron's Avatar
hammeron
may be a grounding issue
measure the resistance between the
engine and the negative battery post
Old Aug 15, 2008 | 11:53 PM
Jersey Stang's Avatar
Jersey Stang
I thought they fixed this issue with the 07's... Your alternater is not generating enough power. If you ingnore this issue, you'll end up with a dead battery soon. Its under warranty and there is a TSB on it.
Old Aug 16, 2008 | 08:48 AM
157dB's Avatar
157dB
Cut & Paste Expert
http://iihs.net/fsm/?dir=10&viewfile...scriptions.pdf
Old Aug 16, 2008 | 10:40 AM
kolb02's Avatar
kolb02
I thought in 07 that they fixed the alternater issue? Everything seems to be working fine, Im stumped and I don't want to take it into the dealership.
Old Aug 16, 2008 | 10:43 AM
mac10chap's Avatar
mac10chap
i threw the P0340 code last night too. i sprayed my giggle juice to test out the higher jets. as soon as i stopped my car, turned it off, then turned it back on, it threw that code.
Old Aug 16, 2008 | 10:49 AM
kolb02's Avatar
kolb02
what year is your car? I don't understand why that error keeps coming up I double checked all my connections.
Old Aug 16, 2008 | 11:06 AM
157dB's Avatar
157dB
Cut & Paste Expert
http://iihs.net/fsm/?dir=26&viewfile...)%20Sensor.pdf
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
ChampInSD
Oct 2, 2015 04:55 AM
