Question, need help
Old Oct 17, 2008 | 11:28 AM
myredgt's Avatar
myredgt
Default Question, need help
Ok, I recently bought a set of Foose Nitrous wheels, I suppose I need to make a new sig eventually, but I now have 18x8 in the front, and 18x10 in the back, sporting some 275's in the back.
I went to the strip, and since I have a Roushcharger, 445 at the crank, around 360 at the wheels for horsepower, and 418 at the crank, around 340 at the wheels in torque, I spin through first second and thrid on the track, getting less than desired times. When crusing at 20 mph and up, when I punch it, Lilly takes off like a bat out of hell, but just no take off traction.
I do not have drag slicks, as I don't go to the track maybe once or twice a year, but what should I do to get better times?
What psi should I put my tires, and what other tips?
Any help would be greatly appreciated. Thanks.
- C
Old Oct 17, 2008 | 12:29 PM
sactown's Avatar
sactown
Drop your tire pressure to around 17-20psi, and slip the clutch some when launching
Old Oct 17, 2008 | 12:30 PM
goldenglory18's Avatar
goldenglory18
lower the rear psi at the track 2 lbs per tire. that should help a little.
Old Oct 17, 2008 | 02:14 PM
Texotic's Avatar
Texotic
if you only go once or twice per year, get a set of used drag radials and 2 cheap rims and swap them out when you go.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
