need help ?
hi ...
hi all , i have a problem with my mustang GT 2005 , it's a stock ... i have check ingine light so i do a dtc read by SCT then i have this message
code # P0340
camshaft position (cmp) A ckt (b1 or single sensor )
so any one can help me about this because i change the camshaft sensor then i clear the dtc after 1 hour it;s show again the same code
please help me
thanx
code # P0340
please help me
thanx
This code indicates a problem with the camshaft position circuit, the whole thing the sensor itself, wiring or pcm. Outside of the sensor itself failing you could also have the following conditions.
* a wire or connector in the circuit could be grounded/shorted/broken
* the PCM may have failed
* there exists an open circuit
* the crankshaft position sensor may have failed
So obviously if you replace the sensor and the problem returned then that's not it. So you want to check the wiring for continuity make sure the sensor is in operating voltage, also check the voltage and wiring of the crank position sensor.
